cedar burls
Blog entry by Pete_Jud posted 203 days ago 156 reads 0 times favorited 8 comments Add to Favorites
I just found a couple of cedar burls that have been drying in a barn for at least 50 years, one has only a couple of checks, the other has a few, the biger one is 27×17x10, the other is around 17×24x12 Im trying to figure out how to cut this stuff as it won’t fit in the band saw, Any suggestions?
-- Life is to short to own an ugly boat.
View Pete_Jud's profile
Pete_Jud
17 posts in 238 days
Entry tags/keywords
View Blog Archive
Recent Entries
8 comments so far
View frank's profile
frank
1389 posts in 691 days
posted 202 days ago
Hello Pete_Jude;
—-and welcome to the world of blogging and wood questions….
Great find on the burls there, but without any photos it’s kind of hard to see what your talking about….so why not include some photos and then we, can give you, our many opinions. Actually I just want to ‘slabber’ some over your great find….and,
Thank you.
GODSPEED,
Frank
-- --frank, NH, http://frank.wordpress.com/
View rikkor's profile
rikkor
7632 posts in 359 days
posted 202 days ago
Great find. Good luck with it, it’s a treasure.
-- Maplewood, MN
View Dooley's profile
Dooley
39 posts in 207 days
posted 202 days ago
sounds like you could get away with using a hand saw, yep I said it.
-- Dooley, Wheat Ridge, Colorado www.myspace.com/smokey4bandit20
View jeffthewoodwacker's profile
jeffthewoodwacker
194 posts in 289 days
posted 202 days ago
As much as I would hate to say this you may have to crank up the chainsaw.
-- Genius is immediate, but talent takes time.
5660 posts in 336 days
posted 202 days ago
It depends what you want to use it for. I thing Jeff has a good option but there is always someone that will have a bandsaw. you could ask any Jocks nearby to help out. With a treasure like that I would think pretty hard about what the end result would be. Lots of luck.
Pete_Jud
posted 202 days ago
Pete_Jud
posted 202 days ago
I just added pictures of the burls, and I still have no idea what to make, Im thinking about sliceing the first couple of 2 inch thick pieces out of the faces and turning bowls out of the remanders. A friend sugested a bow saw at less than 10 bucks for the sliceing.
Any input is valued
View Dorje's profile
Dorje
1745 posts in 482 days
posted 202 days ago
Just noticed you’re from Washington!
I’m not sure how I’d cut them…I’d probably wait til I had the inspiration of what I wanted to make out of them beforehand. But, that may take another fifty years…
That said, it does look like you have the makings for a couple of small live edge table tops if you slab off the top faces of each of the burls. You could also make some interesting door panels out of them (for small cases), by cutting thick enough to resaw for bookmatched pieces. You could use the slabs for a series of drawer faces that would have a contiguous grain pattern. Possibilities are endless. I like your idea of saving some stock for bowls.
I don’t think a bow saw’s gonna do it. You’d run into the frame of the saw and couldn’t get through the entire width. Though you could try coming from both sides and you might just be able to do it, depending upon the size of the saw you use!
Good luck – let us know what you end up doing!
Also – if you put exclamation points just before and just after your hyperlinks for your pics, they should show up in the post…you may have to make your pics a touch smaller though, so they fit in the post window.
Bookmark And Share This Page
