Splash Chair
Blog entry by Dr_Unix posted 74 days ago 129 reads 0 times favorited 0 comments Add to Favorites
Talk about extreme curves, this design takes the cake!
Splash Chair
Even though it wasn’t built out of wood, it very well could have been. Fibeglass makes it lighter. Here’s how the chair was made:
“The chair was sculpted at 1/8th scale using Sculpey clay. From there, the model was cut into ¼ inch slices. These slices were scanned, blown up to full scale, and plotted to be used as a template for the full scale model. From there, the templates were adhered to 2 inch pink insulation foam, cut out, and assembled to the full scale form. Countless hours of sanding later, the form was coated in 4 coats of Elmer’s glue to protect the foam from resin. After the glue was dried, the form was sprayed with chopped fiberglass using a chopper gun. Once dried, the fiberglass was sanded down, then coated with Bondo. After sanding the Bondo as smooth as possible, it was painted with high epoxy glossy white paint.”
Read the full post on Yanko Design.
View Dr_Unix's profile
Dr_Unix
21 posts in 555 days
Entry tags/keywords
chair curves splash design
View Blog Archive
Recent Entries
0 comments so far
Bookmark And Share This Page
