My woodworing ideas and tips #6: Marking and cutting
Blog entry by Betsy posted 55 days ago 210 reads 0 times favorited 15 comments Add to Favorites
« Part 5: Measuring thoughts Part 6 of My woodworing ideas and tips series Part 7: The lowly butt joint »
OK – this is probably going to be very simplistic at best for most, if not all, of you. But I’m really trying to keep my head in the woodworking game.
I’m thankful for the support my fellow LJ’s have been giving me by reading and responding to my blogs.
So onto today’s “tip.” As we all know making/marking a line to use as a guide to cut your board to final length is quite important. If you don’t mark the piece, you have no idea or are just guessing where to cut.
I use a Sharpie to mark out my rough cuts. Some folks use chalk. But I don’t like chalk just because it’s messy and reminds me of Mrs. Walker and her obsessive compulsive need to have a student every morning and every afternoon to clean her chalk erasers. Soooo I have a deep seated aversion to chalk. :-)—- Actually while the Mrs. Walker story is true, I just don’t use chalk. The Sharpie is just more convenient for me.
For my actual cut line I like two methods. A plain pencil line. I make a mark at the end of the square (or at the mark I’m using with a tape).
Then I flip the square around and place my pencil tip onto the line.
Then I slide my square up to the pencil and make my mark.
Another method is to use a marking knife.
A utility knife, like what I used here – is ok—- but a marking knife is a better option. I just could not find my marking knife to do this little tip blog.
When I use a marking knife to score a line I like to use this little tip I learned in a class. Because the scored line is essentially a “knife wall” you can use a chisel to make a “trough” to place your saw blade into before you cut.
I had to blacken out the chip for it to show up in the picture.
You can now use this chipped out portion to slide into the tooth of the blade and you’ll get a perfect cut every time.
Now onto the argument about cutting on the line, on the left of the line or to the right of the line. Take the pencil line or leave it. We woodworkers sure have a lot of questions. Well here is the definitive answer (ain’t I humble??) I take the line—- almost. I like to leave just a hair of the line.
OK – that’s all I can muster today. I hope it’s not to simplistic and maybe just a scooch helpful to someone.
Good health and happy sawdust making to you.
-- Betsy - GO BUCKS!
15 comments so far
View lew's profile
lew
904 posts in 198 days
posted 55 days ago
Thanks, Betsy!
I never knew about the chisel trick!
Tips, Pictures, Demonstrations and Typing- all left handed. Ahh! a woman of so many talents. :>)
Lew
View thetimberkid's profile
thetimberkid
1363 posts in 146 days
posted 55 days ago
Great idea!
Thanks for the post
Callum
-- There is no such thing as a mistake....just a design modification Check out my site http://thetimberkid.blogspot.com/
View Russel's profile
Russel
1214 posts in 382 days
posted 55 days ago
I’m glad I’ve finally got a definitive answer on cutting to the line. Thank you Betsy I do believe you’ve saved my marriage. ;-)
The rest is good. It’s worth the while to have a collection of this information for reference.
View Betsy's profile
Betsy
1760 posts in 339 days
posted 55 days ago
Lew – not so much talent – just desperation to stay connected to my woodworking obsession.
Russell – now I’m a marriage saver – need to update my resume!
Thanks for reading AND responding!
View Sac's profile
Sac
182 posts in 76 days
posted 55 days ago
Good Post Betsy. I like the pencil as well. I have chalk from years ago. The pencil to me makes a more definitive line to follow. I’ve never thought about a sharpie for rough cuts. Good Idea. I’ll have to go look at a marking knife. I’ve never used one. Personally I don’t care for utility knives for marking My line always seems to jump off on a grain line. But that’s just me. I have been cutting to leave some of the line. But if I am not carefull I’ll cut the wrong side of the pencil hairline. So your post has just told me I need to start marking an X on the cut side.
Thanks for the tips Betsy. I’ve been waiting for this follow up from the last.
-- Jerry, Measure 10 times cut once. Set in the foothills of the Smokey's
View suliman's profile
suliman
194 posts in 247 days
posted 55 days ago
Clevar idea !
-- Suliman , Syria, jablah ,
View Allison's profile
Allison
291 posts in 241 days
posted 55 days ago
I am in total agreement myself, I do not like chalk. I too try to just go down the middle of the line. I never have been good at one side or the other. It’s like a passion for me, I want to see a bit of the line on both sides. Betsy, Do you suppose that’s a girl thing?
PEACE!!!
-- Allison, Northeastern Ca. Remember, Amateurs built the Ark. Professionals built the Titanic!
Betsy
posted 55 days ago
Actually Allison—- I only want to see a smidge of the pencil line on one side of the blade (the good side not the waste side). Being able to see only a tiny bit allows me to know that I’ve not taken off too much and that my piece will not be short. I can then tweek it if necessary. If I leave the mark on the waste side then I know my board will be too short and I have to start over.
View romansfivefive's profile
romansfivefive
134 posts in 216 days
posted 54 days ago
I learned so much thanks
-- www.robneves.com
teenagewoodworker
1932 posts in 211 days
posted 54 days ago
thanks for the post betsy! i really like the chisel trick, i might have to try it out sometime!
View Blake's profile
Blake
1874 posts in 317 days
posted 54 days ago
Woa Betsy, you’re gettin’ a little close to that power tool!
I’d never heard the chisel trick before either. Thanks.
-- Dust collectors suck.
Betsy
posted 54 days ago
It felt good being that close to my chop saw Blake. But what you can’t see is that it’s unplugged. Unfortunately for me, it will be at least the Fall before I can plug it back in. Hence I’m writing these little tips to keep my head in the game.
View moshel's profile
moshel
127 posts in 126 days
posted 46 days ago
Thanks Betsy for the post. as for the chisel trick, i saw somewhere that when cutting with hand saw, you can use the same trick along the line of cut (end grain cut) and make a very easy to follow “tunnel”. not sure but i think it was in wood whisperer video.
-- The woods are lovely, dark and deep, but I have promises to keep...
View EdC's profile
EdC
415 posts in 283 days
posted 46 days ago
Betsy,
I am enjoying your posts, you do a good job with explaining things.
-- Ed Collinge- Edmonds, WA.
Betsy
posted 45 days ago
Thanks Ed—I try hard.
Moshel—- I’ve seen the same thing with a saw. It works well.
Bookmark And Share This Page
