So there I am in my little bedroom shop pondering the future and what projects I’d like to build when I’m feeling better. Hummmmm should clean up this mess. Once cleaned maybe it’ll stay that way – until I start working again anyway.
So here I am cleaning up, picking up tiny pieces of wood, shavings, etc. Underneath it all is this miserable looking piece of sandpaper.
Here’s my tip for the day. No matter what brand/type of sandpaper you use—- don’t push it. In other words when you use up a piece of paper, throw it away. Don’t overwork yourself by trying to stretch the paper just a little bit further. The only thing you are stretching is your project time. The grit on sandpaper only lasts so long, when its gone, its gone. The paper backing is simply not going to do the job. Don’t be cheap just get out another piece of paper. You’ll get your project done faster and probably better because you won’t get frustrated with the lack of progress in your sanding stage.
It’s like in baseball—when you try to stretch that single into a double, 90% of the time you get caught. Don’t get caught – get a new piece of paper.
With that said, you can stretch your paper dollars by doing a few little things. First – one thing we all do is wrap paper around a block to do flat surfaces and sometimes different shaped blocks to do contours, etc. This leads to the problem that you only use about 1/3 of your paper, then you get all these little pieces with nothing to use them on.
One way that I’ve started to use to sand with is to take that same piece of paper and the same block of wood and make it into a four sided block. I end up using more of the paper and I don’t wrestle with it staying on the block.
Use spray adhesive and apply to each side of your block and you now have a 4-sided sanding block. Double sided tape would also work but the spray is cheaper, although it does smell.
Let the adhesive dry for a few minutes before you start sanding. Once the paper is used up you can throw the whole block away or peel off the paper and re-use your block. I generally throw the whole thing away since it was scrap anyway.
I’ve also have heard that you can re-use grit 80 for 100, 100 for 150 etc as you grind down the grit. I think that’s just trying to stretch your dollars a bit to far. Then you are also taking time to decide if that one piece is good as which grit,,, not worth it to me.
So guys and gals there’s my little nugget for the day.
-- Betsy - GO BUCKS!
4 comments so far
teenagewoodworker
home | projects | blog
1947 posts in 217 days
posted 67 days ago
some cool ideas there! i agree with you about stretching sandpaper. after most projects i get rid of my ROS pads that are used. i find sanding easier starting with a new piece of paper for each job. not like do a picture frame and throw it away. i still use that for say another picture frame but on bigger projects after using that grit it goes off to the side in case i need it again and after that its gone.
tenontim
843 posts in 193 days
posted 66 days ago
”I’ve also have heard that you can re-use grit 80 for 100, 100 for 150 etc as you grind down the grit.”
This is one of those woodworking myths. If you use 100 grit past it’s usefulness, you don’t end up with 120 or 150 grit, you end up with dull 100 grit.
-- Tim -- http://tmuli.com
lew
945 posts in 204 days
posted 66 days ago
Great information, Betsy!! Thanks
HokieMojo
255 posts in 177 days
posted 66 days ago
This is some great advice. I have to agree with Betsy and Tenontim about the myth of 80 turning to 100 and 100 turning to 150. If this wonderful myth were true, one piece of sandpaper could do a whole job (although I’m sure the myth says it only can go up one grade before expiring).
I was just noticing this weekend how much paper my sanding block wastes. A coincidence that the block is manufactured by a sandpaper company? I’ll never know.
lol.
