Having trouble staying on the net. But will try to load the few pictures that will explain a little of yesterdays classes.
Setting angles for chisels and plane irons—- set your protractor to angle desired.
Set protractor on edge of board/flat surface
Slide the chisel/plane iron, which has been loaded into the edge guide up to the protractor’s blade.
This next picture shows the edge guide with the filing done on the top. You can see it’s only the middle portion that has been filed.
I’m going to post this and then do another post so that I get this on before I get punted off the net. Stay tuned—- had a lot to cover today!
-- Betsy - GO BUCKS!
1 comment so far
EdC
home | projects | blog
420 posts in 328 days
posted 137 days ago
now it make sense what you were trying to explain whaen talking about the board
-- Ed Collinge- Edmonds, WA.
