Hand Tools doings #9: Rabbetted box
Blog entry by Betsy posted 211 days ago 339 reads 0 times favorited 15 comments Add to Favorites
« Part 8: It's a start, first all hand tool project Part 9 of Hand Tools doings series Part 10: Precision cutting »
I’m still experimenting with these hand tools. So far I’ve twiddled with dovetails, butt joints, and now rabbetted joints.
I’ve managed to learn to cut on a bench hook.
The idea of a bench hook to to be able to support your work piece against a fence and have a ledge to cut into – when you finish your cut the saw rests on the ledge and does not accidently fall onto the bench hitting something it should not. You don’t need to clamp your work piece, the hand holding it against the fence is enough to keep it still—this allows you put more finese to the saw and takes less energy to do the cut.
By the way – its still a good idea to keep your fingers away from the saw. Even a hand saw cuts flesh (sorry for the poor picture quality – that hurt and I was shaking a bit..
Next onto the shooting board.
I cut my four pieces and used the shooting board to make the two sides and front and back the same lengths. It’s amazing that you can feel just a very tiny variance between two pieces.
After laying out my pieces to decide where my groove should go for the bottom – I clamped the work piece in my homemade bench vise and used the small plow plane to cut an 1/8” groove.
Yep – the ply fits like a glove.
Now all 4 pieces are grooved.
Next I rabbett the two ends of the front and back.
This is what I end up with after all the cuts.
So here is the finished box.
Notice all the chamfers. That hides a lot of sins! The lid does not sit flat. I still need to do a bit of sanding.
This shows the bottom of the lid. Looks like a beaver got to it.
This is the bottom. You can see it’s not perfect.
I will do a little hand sanding, flock the inside and put a finish on it. It did not turn out to bad. The planes have a learning curve that I’m still working on.
-- Betsy - GO BUCKS!
15 comments so far
View Eric's profile
Eric
668 posts in 273 days
posted 211 days ago
That’s great! Man, I gotta get me some of those specialty planes. The smallest chisel I have is 1/4” so I can’t very well do a groove as narrow as that. I’ve actually thought about filing down and honing an allen wrench (I don’t have a grinder) and just gluing that up inside a block of wood to use as a makeshift tiny chisel.
As for the rabbets – saw and chisel. Not an easy way to do it. I love the look of that rabbet plane – homemade?
-- Eric at http://adventuresinwoodworking.com
View Betsy's profile (online now)
Betsy
1797 posts in 385 days
posted 211 days ago
Eric – I wish I could have made a plane that nice, but nope – its a Lee Valley purchase.
View Eric's profile
Eric
posted 211 days ago
Well, whenever you do get around to making one, I’ll send you my address so you can pass that one along to me. ;^)
9156 posts in 311 days
posted 211 days ago
Very nice, Betsy. You are improving markedly with each post. Are you going to put a finish on your box?
Douglas Bordner
2561 posts in 553 days
posted 211 days ago
Got a nice box and some dandy tools, too. The two Veritas planes and the E.C. Emmerich rabbet plane, I recognize but I don’t know that saw. Whacha got there, Betsy?
Betsy
posted 211 days ago
I’ll keep that in mind Eric.
Doug – its a Japanese saw—- not sure if its the one with the R or the D. But it cuts on the pull stroke, Cuts like a knife through butter actually.
Scott – yes I plan to put a finish of some sort on after I get a little more cleaning up done on it.
I have to give myself props on this though – this all hand tool box actually looks better than my first all machine box. So there is progress being made.
View GaryK's profile
GaryK
8489 posts in 478 days
posted 211 days ago
Boy, you are getting better by the day! Sorry about the boo boo.
View schwingding's profile
schwingding
122 posts in 315 days
posted 211 days ago
That Veritas plow plane makes me plenty envious!
-- Just another woodworker
View johnjoiner's profile
johnjoiner
144 posts in 383 days
posted 211 days ago
Ooh! You have the Veritas plow plane! I played with that for about 20 minutes at the woodworking show a few weeks ago. How do you like it? That can cut rabbets too, though not as wide as the rabbets you cut on your box lid.
Your fillister plane has a scoring blade on it, doesn’t it? That’s supposed to prevent tear-out like you got on the underside of your lid. On your next box you can try scoring a deep line with a knife or even saw a shallow kerf where the edge of the rabbet goes to avoid that tear-out when rabbeting end grain.
You’re assembling a nice collection of hand tools. Nice job on the box!
-- johnjoiner
View davidtheboxmaker's profile
davidtheboxmaker
330 posts in 295 days
posted 211 days ago
You’ve got a nice collection of hand tools developing. Neat box.
Betsy
posted 211 days ago
John the plow plane is sweet! Comes ready to use out of the box. There’s a learning curve on keeping it level – you wouldn’t think so – but it’s easy to tip it one way or the other. It may not be so bad on a larger work piece. The pieces I was working on was pretty small.
As for the scoring blade on the fillister plane – it does have one. The issue is making sure it’s set correctly. I think the knife kerf is a good idea.
Thanks David. Boxes are a favorite – small but still lots to them.
As to the hand tool collection. Well, I look at in as an investment in my health. If only I could my flex plan to apply I’d be in great shape. :-)
View clieb91's profile
clieb91
355 posts in 424 days
posted 210 days ago
Betsy, The hand tool work is looking good. I should invest in some decent planes and use them as well. I do like reaching for the hand tools when I have a chance.
Thanks for posting your journey down this route, look forward to seeing more of it.
CtL
-- Chris L. "Don't Dream it, Be it."
View Blake's profile
Blake
2040 posts in 364 days
posted 210 days ago
Excellent! Great to see some results. Nice job on the first all-hand tool box.
-- Check out my new website! http://www.theeasellife.com
View rikkor's profile
rikkor
7720 posts in 364 days
posted 210 days ago
Way to work the hand tools. This has been an encouraging series.
-- Maplewood, MN
Betsy
posted 210 days ago
Thanks guys. I really do appreciate the encouragement. I’m putting a finish on this box now and will flock the inside then post my finished project. After sanding it a bit, it looks better.
Thanks again.
Bookmark And Share This Page
