Hand Tools doings #4: Second try at hand cut dovetails --- picture heavy
Blog entry by Betsy posted 211 days ago 293 reads 0 times favorited 10 comments Add to Favorites
« Part 3: My first dovetails - warning - kind of ugly Part 4 of Hand Tools doings series Part 5: Third try - hand cut dovetails ---- Sooooo much better »
OK – I failed my first attempt. This attempt at least is closer although the end product does not fit. But I’m getting the idea. So I took lots of pictures to show what I did in steps. I did switch to using popular instead of the red oak. That was a good thing. I definitely need to be more accurate cutting and my paring skills lack quite a lot. But here goes.
First is getting the orientation of your piece. This is important if you are doing a drawer and need the sides to fit!
orient
First half pin – cut with the saw horizontal and going at an angle to the left.
First cut half pin
Second half pin – cut with saw horizontal and going at an angle to the right.
second cut half pin
Both half pins from the top.
Cutting progress
cutting progress
All the cuts from the front and top.
frist round of cuts side
first round of cuts
Chopping out the tails
chopping out the tails
Tails are cut away – leaving the pins.
pins chopped out
Pins from the top.
pins from the top
Placed the pins on the corresponding board to mark the tails to be cut.
marking the tails
Tails are marked out.
tails penciled in
Ready to cut out the pins.
pins marked for chopping
Half pin cut off.
half pins cut off
Tails from the top.
tail cuts
Tails chopped out. Needs a little clean up (ok a lot).
tails after chopping
The first fitting—- really off. But the concept is there.
doesn't fit
After some paring – still needs lots of work. But I’m tired and my chisels need sharpening. That’s something I’m very much still working on.
after a little partin
Well – still no where near even respectable but I had some fun in the shop and practice makes perfect. But I’m done for the day.
-- Betsy - GO BUCKS!
View Betsy's profile
Betsy
1777 posts in 377 days
Entry tags/keywords
hand cut dovetails
View Blog Archive
10 comments so far
teenagewoodworker
2025 posts in 249 days
posted 211 days ago
getting better. i love this progression. i can’t wait until the next one. i know that you’ll get it soon.
View HybridIndie's profile
HybridIndie
5 posts in 461 days
posted 211 days ago
I’ve been doing things like this for months – I head to my shop in the afternoon and pull the chisels, Dozuki and some scrap wood, cut a set of dovetails and then move on to things that help pay my bills. I’m a firm believer in craftsmanship and won’t allow myself to do anything requiring power before I can do it by hand first. You should have seen my first dados =D but practice truly makes perfect, keep it up
-- Such a Beautiful Place When You See It From Space
View GaryK's profile
GaryK
8482 posts in 469 days
posted 211 days ago
Looks pretty good Betsy! You’ll be an ol’ pro in no time.
Other than the angles being a little too steep it looks great. I think the angle should be between 7 and 14 degrees depending on if you are using soft or hard wood. I’d have to look it up to be sure.
Keep at it!
View Mike Lingenfelter's profile
Mike Lingenfelter
389 posts in 595 days
posted 211 days ago
There is always the question, Pins or Tails first. I’m a Tails first guy. If you cut the Tails first you only have to concentrate on the perpendicular cut across the end grain. If your angle cut down the sides of the tail is off a little, it’s no big deal. If you cut the Pins first you have two “perfect” cuts you have to make on the Tails. The perpendicular across the end grain and the angle cut that was transferred from the pins. I think Tails first is easier for beginners. I know I’m going to get an earful from the Pins first crowd. I recommend trying it both ways and find out if one way works better for you.
-- Mike - http://inquisitivewoodworker.blogspot.com/
View Mark Mazzo's profile
Mark Mazzo
292 posts in 394 days
posted 211 days ago
OK Betsy – you are getting there. Here are some points to consider:
As Gary stated, the angle on the tails is a bit too steep usually it is 1:6 for softwood and 1:8 for hardwood. That means for 1:8 every increment over goes up 8 increments (inches, millimeters, feet – it does not matter) I usually just make two ticks on the edge of my bench with a pencil an inch apart and then measure 8 inches up from one and set the bevel gage to that angle.
The pins still could use to be smaller and that would improve the looks when completed but, this is a detail that you can work on after you’ve got the technique down.
As Mike pointed out (I did as well in my response to your post on the previous attempt) cutting the tails first can be a little easier because the remaining pin cuts are a bit less fussy.
The biggest issue that I see with what you are doing is that your tail cuts are at a compound angle and they do not need to be (this is why they do not fit). The tails should be cut perpendicular across the end of the board and at the angle that you’ve marked out from the pins. So, in the pins first scenario as you’ve done, after you’ve marked the tails simply get your square and square each tail line across the end of the board and then cut the tails.
View lew's profile
lew
1232 posts in 236 days
posted 211 days ago
Betsy,
I don’t think there is anything more satisfying than accomplishing hand cut dovetails. Here are two sites I find helpful. I am also learning to cut them and the advice everyone has given is rite on.
http://home.nj.rr.com/afoust/dovetails.html
http://www.handcutdovetails.com/
Hope this helps,
Lew
Betsy
posted 211 days ago
Wow, I really appreciate your help. I just posted my next try and they look better!
Mark – it was the compound angle that got me going—- I did not realize I was doing that.
Lew – I’ll check out those sites. Thanks for posting them.
9026 posts in 303 days
posted 211 days ago
Betsy,
You really are making progress. These are looking better and better. At this rate you may not need to go to your class at Kelly Mehler’s this summer.
Keep working at it you have a lot of support here. We all are wishing you success.
Betsy
posted 211 days ago
Thanks Scott. But I think I’ll still go to school – especially since its paid for!
Dick, & Barb Cain
5043 posts in 780 days
posted 210 days ago
I think it would be easier for you, if shrunk the angle to a bout 7 degrees.
Bookmark And Share This Page
