I tried the box joint again. I must say I did better this time. Blake was right – hand cutting you can’t really stack two boards together (staggered) without gaps from the saw kerf. So these are cut one board at a time. I still don’t have square boards so that is part of the gap issue. Tomorrow I might venture out to the shop to do a few quick cuts to get some square stock.
Anyway, I thought I did ok on these – I could spend some time doing a little paring and I think the joint would be almost acceptable.
You can see on this shot that I’m also playing with hand cut dados. This one is a definite “not good.” But I’m working on it.
If nothing else, I’m passing time and learning how to cut straight!
-- Betsy - GO BUCKS!
3 comments so far
GaryK
home | projects | blog
8487 posts in 469 days
posted 215 days ago
Looks like you need to cut them a little deeper when you clean them up and they would look great.
Just takes time and practice.
9024 posts in 302 days
posted 215 days ago
Betsy,
A definite improvement from your first one. Practice is paying dividends I see. Keep at it.
4129 posts in 727 days
posted 214 days ago
Like Gary said, take a little out of the bottom and you got a good looking joint. mike
-- Mike. Profisher50@yahoo.com
