Hand Tools doings #1: Hand cut box joint
Blog entry by Betsy posted 221 days ago 693 reads 0 times favorited 10 comments Add to Favorites
no previous part Part 1 of Hand Tools doings series Part 2: 2nd stab at hand cut box joint - a touch better »
Since I am not able to be in the power tooled shop, I’m twiddling away in my spare bedroom doing hand tool stuff. Having never hand cut a joint, and after trying a dovetail, without really knowing what I was doing – I decided to back track a bit and do a simple box joint instead. I say simple, but its not as easy as it looks. First you have to be able to saw straight which, I’ve found out, is not an easy task in and of itself.
Anyway, since we learn by our mistakes, and since I know I will make many more, I thought I’d share my first hand cut box joint. I’m glad we are on the internet so I can’t hear the laughing and/or groans. Of course, it would be ok to hear the—- “hey that looks like my first one.” But can’t have it both ways.
I digress. Here is the joint and the crown saw I used.
Now having seen these, let my put in a caveat—I did not have a square board, so some of the gaps is from that. I need to make a shooting board so I can square up the ends. But by eyeball, this board was pretty close so I just used it. So there’s my defense and I’m sticking to it!
-- Betsy - GO BUCKS!
View Betsy's profile
Betsy
1779 posts in 381 days
Entry tags/keywords
box joint finger joint
View Blog Archive
10 comments so far
View GaryK's profile
GaryK
8486 posts in 474 days
posted 221 days ago
That’s not bad for your first attempt. You will get better everytime you do it.
View Eric's profile
Eric
661 posts in 269 days
posted 221 days ago
That’s actually quite good. I just read last night that box joints are almost exclusively machined, since they’re so hard to do by hand. So I, having no machines, have decided that I will have no box joints in my work!
-- Eric at http://adventuresinwoodworking.com
View Gofor's profile
Gofor
57 posts in 272 days
posted 221 days ago
Not bad. I found that using a knife to make my layout marks (as opposed to a pencil) greatly improved my accuracy on fitting joints. Keeping the corners on my chisel square and sharp also helped me get the waste out of the corners so I got a tighter fit in the bottom of the slot, altho you can “cheat” a little by rounding the inside edge of the pin and just leave the exposed end square. Yours sure looks better than my first attempt!! That appears to be white oak, which is not the easiest wood to hand joint either, because of the open grain.
Go
-- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730
Betsy
posted 221 days ago
Thanks guys.
Gofor——I just got a marking knife. I’m going to try using that the next set. The wood is red oak left over from a cabinet I built several years ago.
The sharp chisel part I have trouble with still. But my sharpening skills are getting better.
View kshipp's profile
kshipp
74 posts in 264 days
posted 221 days ago
That looks like a pretty nice joint. You’re more brave than I am for trying that by hand.
I’m curious if you cut each board separately or just offset the second one and cut them both at the same time.
Either way, very interesting project.
-- Kyle, Michigan
9095 posts in 307 days
posted 221 days ago
Betsy,
This joint looks fine to me. I agree with Gary, in that, here practice does make perfect. Keep working at it. You will get better both on the joints and physically as well.
Thanks for sharing this (You are far more courageous than I am. I still haven’t repaired my camera so that is the excuse I will use for not posting my hand cut dovetails, which would be a primer more in how not to cut them.)
Betsy
posted 221 days ago
Kyle – I cut one board at a time. I’m going to try to do the staggering with two boards today and see what happens.
View Blake's profile
Blake
2016 posts in 360 days
posted 221 days ago
Betsy, You’re a brave soul. Not for posting this, but for jumping into hand-cut joinery. I am too timed to try.
I might be wrong, but I think if you stagger them and cut both at the same time you will get gaps equal to the kerf of the saw.
-- Check out my new website! http://www.theeasellife.com
View Shopsmithtom's profile
Shopsmithtom
250 posts in 680 days
posted 220 days ago
I think they look great for a first effort. My first attempt of a hand cut joint was much worse. I like the idea of using a marking knife, too. That’s gotta help. (providing I can actually cut along that line. Hand tools aren’t without their frustrations, but it’s really a great feeling to make something that way. -SST
-- Accuracy is not in your power tool, it's in you
Betsy
posted 220 days ago
You are right Blake!!!
thanks S – right now I’m not frustrated yet. But I’m sure I’ll get there if I don’t get good results soon. I get impatient – but that’s part of using hand tools – you have to be willing to put in the time to get good at it. I’m going to keep trying though!
Bookmark And Share This Page
