need help
Blog entry by jim1953 posted 443 days ago 313 reads 0 times favorited 4 comments Add to Favorites Watch
Hi,
Has anyone ever made a jig for raised panel doors using a table saw? I am re-modeling the kitchen cabinets and want to make raised panel doors.
Any ideas?
-- Jim, Kentucky
4 comments so far
View tooldad's profile
tooldad
456 posts in 612 days
posted 443 days ago
I have not personally, but there are plenty of LJ’s who have and maybe can send you a pic. Basically make a u-shaped sled that goes over your fence with the blade side board being at least a foot tall and 12-18” wide. Set the angle of your blade at the desired angle, about 15deg, clamp board to the jig and slide through. Sorry I haven’t made one because I use a shaper. Hope this helps some.
View SteveKorz's profile
SteveKorz
2030 posts in 611 days
posted 443 days ago
Try this
or maybe this
... or this
(another one)
... last but not least…. always try google .. lol.
Good luck.
—Steve
View corgifrog's profile
corgifrog
3 posts in 448 days
posted 442 days ago
well, I have done this a time or 3. i made a jig that I attached to the tablesaw and ran the wood across the saw blade at an angle. it is better to take very small increments, so you dont get kickback. i had to make some “barn doors” and the taper that was way too big for a shaper was also a cope. draw it out first, then figure your angle and taper if necessary, then try some srap to see if you are getting where you want to be. it is amazing what you can figure out, just remember to be careful, and respect the cutting device!!!
Fine Woodworking #173 has a short article
here are some links…
http://www.superwoodworks.com/Projects/TableSawJig.htm
http://www.newwoodworker.com/pnlrasjig.html
http://www.architectureweek.com/2002/0417/building_1-2.html
hope this helps, but once you start makin jigs, you will lose shelf space fast… kidding
View Bill Akins's profile
Bill Akins
236 posts in 595 days
posted 420 days ago
Check my site out. I made a cedar chest with raised panels on the table saw this summer. Under all projects, you see how I did it. They turned out great. Looking forward to your finished project.
-- Bill from Lithia Springs, GA I love the smell of sawdust in the morning.
