Iam Going To Make My Daughters Kitchen Cabinets With White Ash But I Have Never Used Ash Before They Say It Looks Like Oak But It Is EasierTo Work With I Need Some Help Thanks
-- Jim, Kentucky
Iam Going To Make My Daughters Kitchen Cabinets With White Ash But I Have Never Used Ash Before They Say It Looks Like Oak But It Is EasierTo Work With I Need Some Help Thanks -- Jim, Kentucky | ||||||||
24 comments so far
Dennis Fletcher
home | projects | blog
455 posts in 859 days
#1 posted 822 days ago
I have used it a couple of times. It is very soft and I have never been able to get it to sand down without that little hair like finish.
-- http://www.ahomespecialist.net, Making design and application one. †
Luke
374 posts in 1098 days
#2 posted 822 days ago
I had the same problem on a hall table that I made. I couldn’t get a really smooth surface no matter how much I sanded. It also had a lot of chip out problems. I cut the tree down and took it to a lumber mill then dried it for about 2 years so it should have been fine but to me…. it was difficult. A lot harder to work than the red oak I just made a rocking chair out of.
-- LAS, http://www.abettersign.com
zlatanv
654 posts in 1038 days
#3 posted 822 days ago
Built some raised panel doors for a guy that does remodels, it does resemble white oak and it seemed to work pretty well, seem to work the same as oak, don’t remember having any problems with it.
-- Z, Rockwall, TX
lumberdog
140 posts in 1072 days
#4 posted 822 days ago
I have used it a little bit and found it to work with about the same as oak. take a look at my projects, the frame on the box/coffee table is white ash the top is maple…Jim
-- Lumberdog.. Michigan
Dennis Fletcher
#5 posted 822 days ago
Why is it, then, if it is like oak, that every time I used it, I found it to be like a softwood? Is there a trick to working with it that I didn’t know? I mean, white ash is a pretty nice, clear wood. I would love to work with it a bit more, but I can never get it to finish nice.
Jesse
66 posts in 1023 days
#6 posted 822 days ago
Ash is definitely a “hard” wood. It is used to make baseball bats. I am using it to make my workbench. I find it pretty easy to work, about the same as oak. Hand planes nicely also.
-- Jesse, Hopewell Jct., NY
richgreer
4424 posts in 879 days
#7 posted 822 days ago
For what it is worth— A few weeks ago I turned a piece of ash to make a lamp. I sanded it progressively with 120, 180, 220, 320, and 400. It never took on the feel and smoothness of anything more than 220. I was wasting my time and my sandpaper with the 320 and 400. If I was working on a flat piece I think I would try to finish it with a scrapper. My intuition tells me that it would work well on this wood.
lclashley
244 posts in 1919 days
#8 posted 822 days ago
I just made my son’s bed out of ash, and found it’s workability similar to red oak. It seemed to sand OK to me, although I don’t sand past 150 if I’m going to apply a topcoat.
Daren Nelson
767 posts in 1710 days
#9 posted 822 days ago
I have used quite a bit of ash, I personally like it better than oak since that was thrown out there for comparison. And just for the record on it’s hardness it falls right between red oak and white oak on the Janka scale. RO being 1290, ash is 1320 and WO 1360.
-- http://nelsonwoodworks.biz/
4Bennett
8 posts in 822 days
#10 posted 822 days ago
I used it on our last project at work and would say that it is very similar to oak when it comes to workability and hardness.
trimmer
90 posts in 1245 days
#11 posted 822 days ago
I agree with Daren:
It’s one of my favorite woods. Glue’s well and very stable on movement. Stains very well and has very good grain contrast. If using water borne finishes, i would rate Ash to be better then Red oak, with a close second with white oak.
Beginningwoodworker
12326 posts in 1477 days
#12 posted 822 days ago
I have never use Ash, but like the others say its a good wood.
-- CJIII Future cabinetmaker
Dennis Fletcher
#13 posted 822 days ago
Oh, my, how embarrassing. I just realized, after looking around my desk, I used Aspen, not Ash. I’m so sorry for the mistake. I don’t know why I thought it was Ash.
The Aspen seems very soft, but I haven’t used Ash.
mahadevwood
387 posts in 824 days
#14 posted 822 days ago
you should try to Canadian ash, its very high grade ash, and good strength, density is really very high of other ash wood
-- http://www.mahadevwood.com
roaddog
14 posts in 826 days
#15 posted 822 days ago
I used it for a guitar body that’s still sitting in my shop waiting to be assembled. I liked working with it and didn’t encounter any problems. I was able to get a pretty smooth surface. If you find it hard to get rid of the fibers when finish sanding you might try to lightly wet the wood to raise the fibers and then use a brand new piece of sandpaper to cut them cleanly.
-- Sawdust tastes mighty fine! Doane, Seattle WA, http://www.boatstrips.com
View all comments »
showing 1 through 15 of 24 comments
