"Fold up" ironing board (reverse engineering) #4: Other important details
Blog entry by jeff_wenz posted 09-05-2010 04:23 AM 2977 reads 1 time favorited 5 comments Add to Favorites Watch
« Part 3: Parts list Part 4 of "Fold up" ironing board (reverse engineering) series no next part
So some important details I have not mentioned yet.
The routed groove:
  • There is 2 ½” inches from the front of the case to the groove.
  • The top of the groove bends in ½”
Heat Shields:
Use aluminum for protection. I purchased a 24×6” piece and cut it in half. I sprayed it with white epoxy appliance spray paint then mounted it with 3M’s Super 77 spray adhesive.
Shelf:
Install in coordination with your heat shields. This put my shelf 12” down from the top.
Electrical Unit:
If you decide to use this, install it as far right as possible. I left about an inch space to the right, but now our iron is a tight fit on the left when in storage. Also, the electrical line comes in from the top. this unit cost around $35. I am glad I got it, but it is also an easy upgrade at a later time assuming getting power to the top of your unit is somewhat easy.
Ironing Board Cover:
Lowes sells a cover that should fit the board dimensions I gave in a previous post. If not, use batting and fabric with elastic to make a padded cover. I rounded over the edges of the board using a 1/8” roundover bit.
Board Height:
Our previous ironing board height was 36” off of the ground. This is a comfortable height for my wife, so when I mounted the completed unit, I made sure the board height was around 36”.
Ok, that is all the info I can think of to share. Please let me know if I can answer any questions. Good luck!
—Jeff
-- Jeff, North Carolina
5 comments so far
View lew's profile
lew
12056 posts in 3750 days
#1 posted 09-05-2010 04:03 PM
Great series, Jeff. I like the timer idea. It surely adds to the safety factor.
Lew
View Adam's profile
Adam
1 post in 3044 days
#2 posted 09-13-2010 04:30 AM
Fantastic! I’ve been looking for a “how to” on building a hide away ironing board for some time. Until now the folding and swiveling part had me scratching my head. Now, I have no reason not to cross this project off my to do list. Thanks for posting Jeff.
Adam
-- Adam
View mjzraz's profile
mjzraz
9 posts in 2650 days
#3 posted 06-30-2013 10:54 PM
What is the depth required from face of the frame to the back of the cabinet to get the ironing board in so the door will close? Could it have been flush with the drywall if it were installed in a wall?
I want to do something similar, but I don’t want the face frame sitting on the drywall because my wife actually wants to use an antique shutter as the door or mounted to the door to hide the unit, so the shutter needs to basically end up flush or close to it to the drywall. I guess that leaves me with @4” to work with in a 2×4 wall with drywall.
I think my other challenge will be hinges as the hinge will need to move “out” as we’ll as hinge with the shutter sitting flush
View jeff_wenz's profile
jeff_wenz
151 posts in 3545 days
#4 posted 07-02-2013 12:39 PM
mjzraz,
Good questions. The minimum distance is 3.5” (which should work perfect for a 2×4 stud wall). But you would still have a door of some type sticking out from the wall). I think a shutter would be great. It would look like the shutter was hanging on the wall, but it could be hinged to the drywall. A large picture frame or canvas (in the appropriate dimensions) would also work good.
A piano hinge would be a good choice. Also, certain European style hinge models actually lift the door away from the wall when opened (that would be fully concealed).
In my particular case, I opted to install the automatic outlet timer hardware, so my depth is 7.5”
View ADDmom's profile
ADDmom
1 post in 815 days
#5 posted 02-27-2016 04:40 AM
Hi Jeff, I found your blog in my search for an ironing board setup like this – thank you, this is just what I need. I was also very interested in this community so I joined.
You may not know it, but people may be looking for your article. We’re very sad that the pictures are missing – maybe you could repost them?
Here’s how I found your project. There is a DIYer who was featured on Houzz (a big-deal home decor blog) and she used your instructions as inspiration to build her fold-up and swivel board.
Here’s the article and her video about her laundry room where she shows her board. Not as well done as yours, but it works for her -
http://www.houzz.com/ideabooks/40336773/video/
And here’s her blog where she mentions your instructions and the hacks she had to do for her project.
http://www.batchelorsway.com/2014/06/diy-built-in-ironing-board-part-one.html
Best to you,
Lynn, CA
