I designed, built it, use it, like it….......but what is it??
I have come to a point where I am finishing off a number of shop fixtures. I was thinking I was like Tolkien with his Lord of the Rings Trilogy…....I have read them all…...and then realized I had a quad…......
What a disappointment…...all the famous hip and iconic people, (maybe that’s the problem, I am not hip or iconic), do…..... TRIOLGIES............... Rats.
I even tried to find the word…quadigy. People use the word for things, but it isn’t a real word, I think. But folks seem to think it ought to be a word, because it crops up on searches.
Therefore…....I have a QUADIGY
This is a part of a long saga of intertwined, off beat shop projects that I am about to complete. The only one left of this quadigy is a super sled, which is more mainstream and just waiting for its miter arms. Completed are the panel sled with its oak trimming (Oak Trimming?......for you neophytes to LJ’s, thats what LJ’s do), the dust collector gizmo, and the project table top. All of them are kinda unique and have been used some in an unfinished state (you are thinking that there is nothing really unique anymore, but you have forgotten how nerdy, and off the wall, this old senile Alaskan really is).
But this blog is about….......the gizmo. It is done done done. I know what it does, but I really don’t know what it is!
So here it is:
Kinda like hydra with multiple inputs…...errr…....exputs…......well really…...hmmmm.
........it sucks a lot…......that’s its job….......if it were my job…...yup…..thankfully it is not my job.
So come on, we need a name. It is fed….or drained…..again, this is difficult…by a…..
4 inch dust collector branch tube at the back. A blast gate is installed there.
Why the blast gate? So I can close it off without going all the way to where ever it is hooked up. That way I can quickly turn to another tool that has a nearby blast gate, open it up and use it briefly, close it, then come back to where I was and open the blast gate on the gizmo again, and start sanding, drilling, whatever again.
There are four bullet catches on this thing. They can be pushed back down with some pressure from the acrylic covers, and they pop into an appropriately located hole, so as to firmly hold the cover. With enuf pressure from the cover, they will move out of the way and the cover can be closed again. There are finger holes in each of the covers.
You open and close these covers with a quick forceful snapping action. I like bullet catches, and I have used them in many objects over the years.
This thing slurps a lot of sawdust. The top, front, and both sides have….(no, LJ’s, not orifices).......ports…..that sounds good. Each of the ports has an acrylic cover that covers the port when not in use. The acrylic cover has a hole for a bullet catch so that in the case of sides, the cover will be held by the catch while you are attaching a hose. The top one actually has the bullet catch situated to keep it closed, because gravity is not a factor. At the front there is a slot…..(no…..not a trough)....also with a cover that can be pushed up and is held by the bullet catch.
It is feasible to use two of the ports at a time with the flow from my DC.
Here is a detail of the inside illustrating a port. You can see a 3/4” piece of plywood, with an offset circle cut in it so that one side, in this case the bottom, is open. Meaning you can cut this with a band saw like I did. Then, only the closed side opposite the open side is nailed and glued in place. The circle is cut exactly the same size as the narrowest portion of the tapering hose connector. The the connector can cause the unglued part of the plywood to spred slightly, giving a very tight spring action fit.
This is a very quick and easy way to make ports that exactly fit tapering hose connectors with a tight spring action. You can use a piece of scrap 3/4 inch plywood, and cut it with whatever works for you….scroll saw, jig saw, or band saw.
Now, just for novelty, this gizmo will take an aluminum and MDF slide, inserted in the bottom of the gizmo….... .......so that it can be moved smoothly along, to follow what you are doing. Here it is on my new project table top ready to slide along, as you create sawdust, with some tool or another, on the board clamped in front of it.
The slide is clamped to the table. the gizmo runs over the slide without touching the table, so it is smooth. And the gizmo has flanges which grasp the slide so that it will not tip or come off.
Anyway, I know what you are all thinking….over engineered….is that a compliment or not? Time to lay down the glove and tell me where you stand.
OK, OK, OK. Back to the business of explaining why in h… I made this abomination, that looks like it has been transplanted from some Greek mythologic horror story…..with the gizmo being one of the monsters.
I was making this project table top…....one of the quadigy.....also now completed, and I was having MDF dust flying everywhere as I routed slots, all the way through the MDF, meaning sawdust could exit out the top and the bottom, and hence was making a real mess. I found I was hooking up hoses, and trying to clamp them in place, usually in an unsatisfactory fashion, partly because the router and the drill were on the move and quickly got out of range of the dust port. Hence, I invented this gizmo, with options for one or more smaller hoses, or just a slot opened in front to place near the workpiece.
So there you have it. A device to facilitate dust collection from drills, sanders, routers, circular saws, etc. This gizmo can be clamped near to the action, or if the action keeps moving, moved along a slide without having to reclamp it in a new position.
We need both a descriptive name….....and of course….....Neil will demand that it have a pet name.....you know, a name like Norton, the shop mascot, the fancy sanding block has.
So what would be a good descriptive name, that lets you know what we are talking about? And then to individualize it, give it personality, something I can talk to when I have a lonely day, what would be a good pet name?
Thanks for viewing
Alaska Jim
-- Jim, Anchorage Alaska
39 comments so far
home | projects | blog
87379 posts in 1750 days
#1 posted 944 days ago
Cool very well done
Jims deduster :)
Jim Bertelson
3337 posts in 1337 days
#2 posted 944 days ago
Thanks Jim
DeDuster........hmmmm, that is a good one….......
Dennisgrosen
10854 posts in 1288 days
#3 posted 944 days ago
hello Jim
first : realy great to see you posting again and in the best performens ever :-)
that vacation has been realy good to you
second : all I can come up with is from my days in the trucks trugh europe
and its a part in the compressor/breaking system that destribuate the compress air
out to the diffrent parts that needed the air the name of that part is (direcly translated from Danish)
four way valve and I realy think thats what you have made here just with a decompression/suction system….LOL
third: a name Hmmmm…........there you got me sorry
have a great day Jim
take care
Dennis
lew
8989 posts in 1928 days
#4 posted 944 days ago
I think we should call him Gort because there is no limit to what he can do.
Reference the 1951 movie “The Day The Earth Stood Still”—
Klaatu: I’m worried about Gort. I’m afraid of what he might do if anything should happen to me.
Helen: Gort? But he’s a robot. Without you, what could he do?
Klaatu: There’s no limit to what he could do. He could destroy the Earth.
Nice dust collector, Jim!
Lew
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
Jim Bertelson
#5 posted 944 days ago
Dennis
Decompression/Suction System
I think that is tooooooooooo…......descriptive. We could name him DECOM, or some such thing…..(-:
You are in the running, but a1Jim is in the lead with DeDuster.
Thanks for coming by Dennis…....(-:
Be sure to check out my next blog in a row today….......
Jim
Dick, & Barb Cain
8681 posts in 2472 days
#6 posted 944 days ago
Hi Jim!
It looks like some sort of manifold to me, so the only name I could think of is a little lengthy.
The HANDY DANDY DUST MANIFOLD.
It took me all of about two minutes to dream up that name.
If I wasn’t so busy, <(:O}$ maybe I could think of something better.
Dennisgrosen
#7 posted 944 days ago
I will do that Jim
and Gess you are right since decom is a little too close to DEFCOM…..LOL
Dennis
dbhost
4748 posts in 1404 days
#8 posted 944 days ago
I think it should be called Alaska Jim’s Super Duper Dust Collection Manifold Thingamajig…
Roger
9219 posts in 977 days
#9 posted 944 days ago
I am speechless Jim
Jim Bertelson
#10 posted 944 days ago
Lew
That is funny, because I have already used that name to describe my new computer, the case is brushed aluminum, and it is quite capable, to say the least. I saw the original when young in the theater, and I have seen the new version as well.
My project table top blog, just done, is of more import to the functioning of the shop, a real winner. Be sure to take a look….....
http://lumberjocks.com/jbertelson/blog/18854
Thanks for viewing Lew…........
Jim
David Craig
2127 posts in 1281 days
#11 posted 944 days ago
Well I believe dustbuster is already in use. We could call it the “Soil Foil” but soil gives more the impression of earth. The “Grain Drain” might be more suiting since we are talking about small particles or granules. If this was used in more murky situations, the “Muck Suck” would be a good one. Since it is a four way device, we could call it the “Quad Pod.” Brief and to the point you are looking for I know. After all, we do not call a Coke “a fizzing beverage that can make you belch a lot”
Nice contraption Jim. I hope the devices are as much fun to create as they are to admire.
David
racerglen
1700 posts in 953 days
#12 posted 944 days ago
Jim..!
“SNORK”
-- Glen, Vernon B.C. Canada
Jim Bertelson
#13 posted 944 days ago
Dick
Glad to hear you are just loafing Dick, watching Barb look for and dust off the next project blog in the closet…...(-:
I have really been having fun in the shop, that vacation was something I really needed. My first real project will possibly involve some carving…..I will be knocking at your door buddy, so keep alert…..(-:
Jim
Jim Bertelson
#14 posted 944 days ago
dbhost David
OK, you have been spending way too much time with the dictionary, and I have been spending too much time with MDF and plywood. I am waiting to see a panorama shot of the garage sometime this winter….......nah…....you guys don’t have winter (Sherie will be down in Houston next week for a quilting thing…...leaving me at home….sigh). Anyway, was looking very close at stuff to build a Thein separator yesterday, so I will be leaning on you for real info soon.
Have a good Halloween, you and LOYL…....did I abbreviate that properly?
Jim
Jim Bertelson
#15 posted 944 days ago
Roger
Thanks for the speechless, Roger…............(-:
View all comments »
showing 1 through 15 of 39 comments
