Well, after finishing my downdraft table (see my blog, Revamping and Updating My Old Shop), and making my dutiful post about it here, I started to clean up the shop. So moving stuff back where it belonged, the two-bit (pun intended) router table went up high on a shelf, moved off a generic rolling stand that I use for all kinds of stuff, and then I looked about for a place to put the downdraft table. (This shop desparately needs wall space and, it will take cabinets and big time organization to accomplish that).
I looked at the stand the router just came off of….......and plunked the downdraft table on it…....and laughed. It fit perfectly. But the funny part of it is, I suddenly remembered where this stand came from. It has a handle on the left for rolling. It normally sits on all four legs, but if you lift up on that handle, then the casters, that are normally just barely off the ground become the lowest point, and off you roll. I had built a plywood top, and a shelf for what was a barebones iron stand. It is heavy sturdy, portable, was given to me, and except for the casters, was built from scrap. The stand that I started with is just the iron part.
I built this about 17 years ago….....
Here it is, this is an easy one…....the stand was given to me, I used it briefly, and I was going to throw it out before I had the inspiration and turned it into a utility cart….......
What is it. Easy.
-- Jim, Anchorage Alaska
3 comments so far
home | projects | blog
16852 posts in 473 days
posted 30 days ago
Got er done good job.
stefang
1650 posts in 230 days
posted 30 days ago
Nice downdraft table and cart. I like your wheel solution.
-- Mike, American in Norway
Jim Bertelson
280 posts in 60 days
posted 27 days ago
Oh, and by the way, the original cast iron stand was an aquarium stand. I got it when I lived in Fairbanks, a quirky hand me down from a brother-in-law, and I was cleaning up space, about to throw it out, and dreamed up this rolling shop stand instead. Alaskans don’t throw out much, use duct tape to fix what looks unfixable, and make junk do the job. It is in the culture. This stand is extremely heavy for its size due to the iron work and heavy wood work. It makes a great router stand, small project table, and probably now a downdraft table stand. The caster system works perfectly….....
Thanks for the comments and reads.
