Shop Upgrade #1: Pics of the new shop in progress
Blog entry by itsme_timd posted 02-26-2008 08:44 PM 867 reads 0 times favorited 7 comments Add to Favorites Watch
no previous part Part 1 of Shop Upgrade series no next part
Hi Folks,
Wanted to share a few pics of my shop upgrade in progress, I’m a bit into it now but nothing that is too advanced – just some basic framing. I’m working out of a 2-car garage and wanted to maximum my shop space while still retaining some use of the garage.
The major tools that I needed to accomodate were:
- Grinder
- Drill press
- Spindle sander
- Mini lathe
- Bandsaw
- Tablesaw
I built the bench to hold the grider, drill press, sander and lathe with a spare bay as an ‘assembly station’. I also installed a Delta AP400 dust collector with the hoses running under the worknbench. At each station there is a blast gate mounted flush with the bench and next to the dust collector I have a floor sweep.
I still need to run an auxilaary line to connect on the table saw and planer – once I get one!
Here’s a picture of the bench -
The worbench is 21 3/4” deep, this makes it flush with the door leading into the house. There’s still room a the opposite end to store our lawnmower and access the water heater.
I try not to waste anything in the shop so for the bottom shelves I used random pieces of 2×4’s to create cross-support braces – reminiscent of setting up a waterbed frame in you remember those. Since they won’t be visible they only needed to be functional and not visually pleasing.
Here’s a pic showing one of the supports:
My plan for here is to finish closing in the worbench. I’ll add 2 doors at each bay. For the bottom shelf I’m going to use drawer slides to make a sliding shelf for easier access.
Still to come are a rolling bench to be used as a miter saw staion, possibly with a router table integrated. Once everything is situated this should still leave 1/2 where a car can be parked if needed.
Any comments or suggestions are welcomed and appreciated!
-- Tim D. - Woodstock, GA
7 comments so far
27251 posts in 3729 days
#1 posted 02-26-2008 09:06 PM
Tim,
This is a nice space. I particularly like the mats in front of the bench. The bench looks pretty solid. I am interested in seeing the finished pictures as well.
View GaryK's profile
GaryK
10262 posts in 3895 days
#2 posted 02-26-2008 11:23 PM
Looks like it will do the job for sure.
35099 posts in 4307 days
#3 posted 02-27-2008 05:33 AM
Great Tim. Looking great.
View Mario's profile
Mario
902 posts in 3958 days
#4 posted 02-27-2008 04:42 PM
Nice work, keep that pics comming.
-- Hope Never fails
View HallTree's profile
HallTree
5664 posts in 3674 days
#5 posted 02-27-2008 05:14 PM
Looks like you are off to a good start. Looking forward to see the projects that come from all of it .
-- "Hold on to instruction, do not let it go; guard it well, for it is your life" Solomon
View lance's profile
lance
170 posts in 3895 days
#6 posted 02-28-2008 09:21 PM
Great! Good Luck.
-- Bob Lance, DE
View davidtheboxmaker's profile
davidtheboxmaker
373 posts in 3712 days
#7 posted 02-28-2008 10:36 PM
The bench looks very solid and dependable – just what you need.
I’m jealous of your space – I work in 8’ x 10’ – its good, but I’d look more room.
