Workbench base in progess.... #4: The short rails...
Blog entry by Mike posted 08-15-2007 03:06 PM 1071 reads 0 times favorited 5 comments Add to Favorites Watch
« Part 3: Trouble with the first foot and legs... Part 4 of Workbench base in progess.... series no next part
Well…the temp outside dropped pretty quickly (lower 80’s) this evening and I was able to get out in the garage and work on the base some more. I had a noble idea of hand chiseling the mortises for the rest of the base. I don’t mind doing this, but I want to get this base done so I abandoned that idea this evening. After chiseling last night for a couple hours and this evening for a bit more I decided I needed to utilize the tools at hand. I proceeded to turn on the drill press with a 3/4” forstner bit and cleaned out the two mortises in about 10 minutes. I still have quite a bit of clean up, but the majority of the material is out.
I made a slight mistake in cutting the pieces for the rails. I cut them to the exact finished length and left myself no room for error during glue up. Well….I had error and the shoulders were not even so I had no choice but to add material that will be cut to make the lengths perfect. I only needed about 1/32” but I figured it would he easier to glue the thicker piece. I’m taking notes at every turn on this project. I love it!!
-- Mike, Charlotte, NC
5 comments so far
35120 posts in 4396 days
#1 posted 08-15-2007 03:24 PM
Good recovery. Good luck on the finishing work.
View Mike's profile
Mike
25 posts in 3951 days
#2 posted 08-15-2007 03:25 PM
Thanks. I’ll post pictures of the finished joint so everyone can see how it turned out.
View Partridge's profile
Partridge
296 posts in 3951 days
#3 posted 08-15-2007 05:25 PM
good thinking adding wood instead of settling
-- I get out in the shop when I can
View Bob Babcock's profile
Bob Babcock
1804 posts in 4081 days
#4 posted 08-15-2007 07:28 PM
Good save… FWW had an article on fixes and this was one of them.
View Mike's profile
Mike
#5 posted 08-15-2007 09:08 PM
Thanks Bob. I hadn’t seen the article and couldn’t find my board stretcher so the only option was gluing additional wood on the end. I will post another entry when I get around to cutting the shoulder.
