Planning and Getting Started
Our basement needed new paint and flooring and a few minor renovations. In our large "living room" or "rec room" I wanted to put up a beam with lights in it. Here is what I was dealing with:
(Right side below
(Left side below
My original plan was to put a wood beam up against the bulkhead (lower) portion that contains some ducting. Because of the two vents in the ceiling, I realized that would be impossible without a lot of tearing out, so I decided to put the beam below the bulkhead instead.
The total length, just under 16', was far too long to put one piece of wood, so there had to be joints in the beam. Instead of just straight joints I realized I could highlight the joint and make it look like a dovetail, so I made two joints along the length of the beam like this:
The beam would be hollow and allow four pot lights to be put inside. I decided to make it like this, with plywood sides and bottom, and 2Ă—2's to screw the box sides to.
I used basic (rough) plywood which I cut into strips. I drew out a dovetail on the end of my side pieces and cut with a jigsaw.
I then laid the cut piece over another to mark and then cut the piece that the dovetail would fit into.
This is how they would look joined together:
I measured out to find where the holes needed to be for the pot lights and cut those out of my bottom pieces:
I screwed the 2Ă—2 pieces to the ceiling after finding wood studs behind. You can see that I set them back from the front the thickness of the plywood, so that when the beam is up it will run even with the front vertical bulkhead wall. My husband set up the electrical wiring so that it came out where the end of the beam would be. You can see those wires hanging down at the bottom of this photo. This runs from two switch boxes, one at the bottom of the stairs and one at the opposite far end of the beam.
(Left side below
(Right side below
I'll be back next time to show you how it all went together, stay tuned!
(Right side below
(Left side below
(Left side below
(Right side below
