Router Table by Julie #7: Completing the Drawers
Blog entry by ~Julie~ posted 03-21-2014 05:40 PM 1679 reads 2 times favorited 9 comments Add to Favorites Watch
« Part 6: Adding the ON/OFF switch ... finally Part 7 of Router Table by Julie series no next part
After getting the switch installed in the top “drawer” area, I needed then to make two drawers below that, on the left hand side.
I had two drawers that were part of an old entertainment unit that we threw out. I kept some parts including two drawers as well as drawer slides. The drawers were too wide for my router table:
So, I taped the drawer slides into the cabinet and measured the width I would need for my drawers to fit:
Then I cut the drawer, allowing for the side to be put back on after knocking it off (it was nailed on):
The next step was to use nails and glue and remake the side. I sat it on the drawer slides to check the fit:
Now, the drawer was also too high for the cabinet, so I clamped the drawer front on to determine the height:
I cut the height down with my jigsaw:
Then I attached the drawer front as well as the slides (they are a bit long, but it doesn’t matter, they were free):
Perfect!
The second drawer was a similar process, putting the slides where the bottom drawer wouldn’t interfere with it:
Then cutting the drawer down and putting the front on:
In my case, the front of both drawers are not centered on the drawers, so I had to clamp them in place and make sure they lined up properly with the other components:
I also put a pine edging around the top of the cabinet. Here she is ready to go:
P.S. I use an old pill bottle, turned upside down over the bit, if it’s still in the table. This protects me and the bit.
-- ~Julie~ followyourheartwoodworking.blogspot.ca
9 comments so far
View Handtooler's profile
Handtooler
1493 posts in 2008 days
#1 posted 03-21-2014 08:07 PM
Great blog! Thanks. I’ve certainly learned something about salvaged furniture parts, and it’ll be of use to me in the future. From where did you purchase or get the bottom drawer slides, please?
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View jinkyjock's profile
jinkyjock
488 posts in 1450 days
#2 posted 03-21-2014 09:07 PM
Great job on the re-cycling. You now have a really neat work-station, AND you saved cash
View ~Julie~'s profile
~Julie~
607 posts in 2910 days
#3 posted 03-21-2014 09:27 PM
Russell, I used the drawer slides from a unit I took apart. They are available in most hardware or DIY type stores.
View gfadvm's profile
gfadvm
14940 posts in 2566 days
#4 posted 03-22-2014 12:38 AM
Wow Julie, That looks like apiece of furniture! Great job of repurposing those drawers (your jigsaw works a lot better than mine!)
View justoneofme's profile
justoneofme
639 posts in 2356 days
#5 posted 03-22-2014 05:14 AM
That looks totally awesome Julie!!
-- Elaine in Duncan
View Roger's profile
Roger
20898 posts in 2680 days
#6 posted 03-23-2014 11:48 AM
This could be sitting in a living room, it’s so nice. Super build. I like the pill bottle idea. Gr8 stuff.
View niftynoel's profile
niftynoel
108 posts in 1422 days
#7 posted 03-25-2014 04:20 AM
WOW!
-- Noel
View WebErika's profile
WebErika
104 posts in 1405 days
#8 posted 03-25-2014 04:36 AM
Beautiful table! Great job :)
-- Have a happy day!
View JoeinGa's profile
JoeinGa
7732 posts in 1883 days
#9 posted 03-25-2014 12:08 PM
Good idea on the pill bottle safety cover
