Router Table by Julie #6: Adding the ON/OFF switch ... finally
Blog entry by ~Julie~ posted 03-17-2014 09:27 PM 2583 reads 0 times favorited 10 comments Add to Favorites Watch
« Part 5: the doors and drawers Part 6 of Router Table by Julie series Part 7: Completing the Drawers »
I cannot believe it has been 1111 days since I posted about my router table. And I never finished it until recently, a bad habit of mine.
I had the drawer fronts ready to go, but had to make some drawers. I just never put the drawers together and I was using it without them, I’ll show those in the next post. The switch I’ve had installed for a few years, so I’ll show that now.
This is where I left off all those days ago:
I had asked about ON/OFF switches and someone recommended the Kreg switch, which is what I went with. The Kreg switch is meant to be installed vertically on the metal leg of a Kreg table. I had no such place, because my table was already made, but I figured out what to do with it. I decided to mount it horizontally in the top drawer front, by cutting out the exact shape of the switch:
Then I fit the switch through from the front:
At first I thought I would just screw the drawer front in from the back and leave it permanently attached there. Then I realized that it would be hard to unplug the router from the back of the drawer without contorting my hand and opening the drawer below it. I use my router out of the table sometimes, and also prefer to unplug it when I do any bit changes, of course.
So, this is what I came up with:
The router plug comes through a hole in the side wall in the cabinet. The switch cord runs straight out a hole in the back wall.
I put a short piano hinge on the left side of the drawer front (which is now a small door), this matches the hinge on the three large doors. I also attached a spring type latch to hold the drawer/door shut. This works perfectly for me!
I added matching knobs to each door as well as the drawer/door.
Next I’ll show how I made the drawers, hopefully in a day or two, and not 1111 days!
... to be continued …
-- ~Julie~ followyourheartwoodworking.blogspot.ca
10 comments so far
View stefang's profile
stefang
15881 posts in 3415 days
#1 posted 03-17-2014 10:11 PM
Good idea for the switch placement and a good build on your router table.
View justoneofme's profile
justoneofme
639 posts in 2561 days
#2 posted 03-17-2014 10:42 PM
Hi Julie: you will totally enjoy this workshop addition once it’s all finished! I have a similar router table passed down from my (now totally retired) wood work’n buddy a few years ago. Mine is a bit more ‘rustic’ looking … but does the job! The on/off switch is activated by pushing the front panel just below the table top, making it simpler than having to look for the on/off switch. The only drawback to that is while the grandkids are in the workshop, I have to make sure to unplug my router table!! Great woodworking project Julie!
-- Elaine in Duncan
View oldnovice's profile
oldnovice
7016 posts in 3449 days
#3 posted 03-17-2014 10:52 PM
That is a very good router table and it look like it will serve you well for many years.
Thanks for sharing this fine effort.
View daltxguy's profile
daltxguy
1373 posts in 3995 days
#4 posted 03-18-2014 12:00 AM
I’ll be waiting anxiously for 1111 days again for your next installment!
Looks great so far and I’m sure it has been very functional for a long time!
-- If you can't joint it, bead it!
View cbfodalo's profile
cbfodalo
22 posts in 1628 days
#5 posted 03-18-2014 12:10 AM
I have been thinking of picking up the kreg switch, is it worth the $35 that amazon charges?
Nice Router table, what are you going to use for a fence, dust collection? looks like a very nicely made piece, furniture grade. Congrats.
-- Healthy Homes, NJ LLC
View Mean_Dean's profile
Mean_Dean
6790 posts in 3228 days
#6 posted 03-18-2014 12:41 AM
Great looking router table! Once you’ve finished it, you’ll use it on every project!
-- Dean -- "Don't give up the ship -- fight her 'till she sinks!" Capt James Lawrence USN
View janice's profile
janice
1117 posts in 3506 days
#7 posted 03-18-2014 02:53 AM
That looks very nice and very well built! A lot of thought went into that, I can see why it took so long.
-- Janice
View NormG's profile
NormG
6216 posts in 3085 days
#8 posted 03-19-2014 01:10 AM
That looks great, persistence pays off
-- Norman - I never never make a mistake, I just change the design.
View Grandpa's profile
Grandpa
3260 posts in 2756 days
#9 posted 03-19-2014 02:16 AM
Looks great!!
View ~Julie~'s profile
~Julie~
607 posts in 3115 days
#10 posted 03-21-2014 05:55 PM
Thank you for the kind comments.
To answer “cbfodalo” I really like the switch, it is pulled out to turn on the router and pushed in to turn it off. I find it handy to have and easy to use.
