Workshop Interior Doors #8: hanging the doors
Blog entry by ~Julie~ posted 75 days ago 589 reads 0 times favorited 4 comments Add to Favorites Watch
« Part 7: hinging the doors Part 8 of Workshop Interior Doors series no next part
Finally hanging the doors is the next step in this long process.
I stand my doors in the opening they will go and put them on a flat scrap of wood, just enough to give the clearance under the door that I want. I use about 1/8” – 3/16” up off the floor. Then I mark the top and bottom of the hinge recesses I’ve already cut out on the doors. I tape a hinge onto the door frame at the correct spot and trace around it with a pencil:
Then I carefully cut around the pencil marks, to a depth of about 1/16”, with a sharp knife:
As I showed in the previous post, my router bit was set to the thickness of the hinge:
Then, I routered out the space by hand being very careful to stay inside the cut lines. I could have tried to clamp some type of stop blocks on the frame, as I did for the doors, but I didn’t do that.
This was a little difficult to do the top hinges, since I had to stand on a chair, but anyway…
I was very careful and watched through the opening in the router base to see where I was:
I cleaned up the uneven spots and squared up the corners with a chisel and the hinge fits right in:
My dogs watched the process intently!
These are hinges with removable pins so I screwed each hinge side to the doors and the other side to the frames. Then I lined them up and dropped the pins in.
I have not finished the door rails and stiles with polyurethane yet, just the panels and the door frames, so the colour is different, but here’s the doorway between my shop and my front room:
and here is the doorway between my shop and my husband’s garage:
Now I need to make some door stops, the narrow strips on the door frame that doors butt up against when closed. Also I have to cut the windows and make strips to hold them in.
-- ~Julie~ followyourheartwoodworking.blogspot.ca
4 comments so far
View grizzman's profile
grizzman
5392 posts in 1473 days
#1 posted 75 days ago
beautiful doors Julie, you did a down right perfect job, and i love your doggies…are they Shelties or collies….im guessing Shelties…but they are beautiful…i love animals…those doors will be something to admire each time you pass on by…grizz
-- GRIZZMAN ...[''''']
View ~Julie~'s profile
~Julie~
525 posts in 1204 days
#2 posted 75 days ago
These are rough collies, the blue merle is a male, Billy… official name is “Follow Your Heart” and the sable is a female, Twister, official name is “Twisted Magic.” As much as I love them, their hair in my finishes does not make me happy! LOL
View justoneofme's profile
justoneofme
357 posts in 650 days
#3 posted 74 days ago
Totally beautiful doors Julie!! And many thanks for the tutorial blogging throughout. That was great to watch and easy to follow. I love your ‘admiration society’ Billy and Twister!
So Julie … what do you plan to put in the windowed areas?!
-- Elaine in Duncan
View hjt's profile
hjt
549 posts in 1308 days
#4 posted 71 days ago
Nice work, kid. And beautiful dogs too!
-- Harold
