Routed Out Serving Tray
Blog entry by ~Julie~ posted 177 days ago 1800 reads 21 times favorited 15 comments Add to Favorites Watch
I decided to use some of my wood stock to make some trays. I started with a piece of wood that I needed help identifying and had help from fellow lumberjocks to do that. It turned out it was birch which I planed down and cut to the size of 25” long x 7 1/2” wide x 13/16” thick:
For 3” at each end, on the underside of the piece, I routed out a depth of 5/16” using a bowl bit:
(This was cleaned up afterwards with a sander.)
Here you can see the profile of the tray from the side:
I then drew out a rectangle 17 1/4” x 6 1/2” that I would route out inside the tray on the top side:
I proceeded to route out 3/8” deep
Once it was routed out I sanded, sanded and sanded some more:
I coated the whole board with mineral oil, let that soak in and then coated it again:
Hope you like it!
-- ~Julie~ followyourheartwoodworking.blogspot.ca
15 comments so far
View Monte Pittman's profile
Monte Pittman
7069 posts in 508 days
#1 posted 177 days ago
Nice job cutting and routing. Nice clean work. Good tutorial.
-- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability
View grizzman's profile
grizzman
5389 posts in 1473 days
#2 posted 177 days ago
i really like this Julie, good job on the routing, did you free hand it or use a guide for the sides and ends, to me its very contemporary and it would look very nice on anyone’s table, i might do one like this except with walnut.thanks
-- GRIZZMAN ...[''''']
View ~Julie~'s profile
~Julie~
524 posts in 1204 days
#3 posted 177 days ago
Grizz – I learned a lesson making this, which would be to have the wood piece larger than the final piece and to screw a template onto the wood. I clamped border pieces around the “rectangle” for the router bit to ride against, and, because I kept running into the clamps, had to keep changing the placement of them. This did not give me a perfectly smooth edge, I had to keep going back to clean up the side lines.
View Roger Clark aka Rex's profile
Roger Clark aka Rex
6245 posts in 1604 days
#4 posted 177 days ago
That turned out really good Julie, I like the clean lines and grain, it’s very functional and something I may like to try to make. Well done.
-- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time.
View LelandStone's profile
LelandStone
68 posts in 683 days
#5 posted 177 days ago
Julie, I like the clean lines and clear functionality of this piece. The wood grain is really highlighted and thanks for offering this bit of inspiration and help. :)
Leland
-- Leland, OC Calif., www.safetyshowerbars.com
View prattman's profile
prattman
396 posts in 287 days
#6 posted 177 days ago
I really like this, you have inspired me to try something like this. thank you for posting this Julie
-- Everyone calls me Ed or Eddie , mom still calls me Edward if she is mad at me.
View degoose's profile
degoose
6594 posts in 1524 days
#7 posted 177 days ago
I dreamt of making a routed tray last night…....I am going to make the template in acrylic on my laser and use a bowl bit with bearing… how bizarre that you post this now… and btw … nice job…
~Julie~
#8 posted 177 days ago
Larry, perhaps I sent brainwaves across the globe? Yes, do make a template, it will make things much easier and neater. Be sure to post your creation!
View Douglas's profile
Douglas
171 posts in 730 days
#9 posted 177 days ago
very nice. I want to start making some router bowls and such myself—thanks for the inspiration. I just need a bowl bit.
-- Douglas in Chicago - http://dcwwoodworks.com
View daltxguy's profile
daltxguy
1323 posts in 2084 days
#10 posted 177 days ago
Nice work Julie. You made an excellent choice on how to use this pretty piece of BIRCH.
It’s a wonderfully simply looking design, though we all know that it takes work and effort to make it look simple.
-- If you can't joint it, bead it!
View Grumpymike's profile
Grumpymike
633 posts in 485 days
#11 posted 177 days ago
What a wonderful little tray! I’ll bet that hundreds of copies are under alot of Christmas trees this year.
I started my template this afternoon.
Thanks for your post Julie, you have inspired many … and me.
-- Grumpy old guy, and lookin' good Doin' it.
View EWJSMITH's profile
EWJSMITH
66 posts in 1996 days
#12 posted 177 days ago
beautiful tray indeed. I too will be borrowing the design. I may combine what you have done with the small dish holders I did to make a larger serving tray with the dishes on the side.
i don’t have a bowl bit for my router. can the same be accomplished with a corebox bit? with regards to finish, i know mineral oil is the usually the standard for trays, bowls, boards, etc…. how does that hold up to stains? the small bowls i would incorporate would hold condiments and my concern would be the tray being stained up. my dish holders were finished with shellac but there isn’t any food contact with these as they just hold the dishes and the spoons.
cheers
View harry1's profile
harry1
362 posts in 455 days
#13 posted 177 days ago
A truly amazing job Julie and the method used was fine for a one off even though heaps of sanding was required. All it takes to produce multiple identical ones with minimal sanding is two very simple templates, similar to the ones shown in my thread on making a marble solitaire game.
-- Harry, Western Australia
View hjt's profile
hjt
549 posts in 1308 days
#14 posted 176 days ago
Ditto!!! Julie you do beautiful work, be it rough or fine, you are very talented! Are you planning to make a bunch to sell? If so, what means might you sell thel – art/fair settings? Consignments? Wholesale???
-- Harold
View Napaman's profile
Napaman
5015 posts in 2247 days
#15 posted 176 days ago
very nice…
-- Matt--Proud LJ since 2007
