Routing a Sign #3: Finishing the sign
Blog entry by ~Julie~ posted 09-27-2012 11:05 PM 2293 reads 3 times favorited 11 comments Add to Favorites Watch
« Part 2: Routing the Horizontal and Vertical Parts Part 3 of Routing a Sign series no next part
I’ve finished the horizontal and vertical portions of the letters and now move on to the straight angled parts. This would include both sides of the V, as well as the A and the leg of the R. These are basically done the same way, by clamping a scrap piece of wood at the offset distance away from the letter being routed. I had to brace underneath my scrap piece to clamp it securely.
The router then rides again along the side of the clamped piece.
Now… the hard part! For the remaining curved parts of the letters, such as the top of the R’s, the B, the bottom of the U and the C and of course the very curvy “&”. You really need to hold tight on the router and try to keep within the drawn lines. As I said in Part 2, it’s not perfect and it helps to practise a bit first! Here are the finished letters:
First I take off the support wood underneath and trim the wood to size. I then give the board a good sanding which can help remove some of the fine bits you sometimes get around the edge of the routed out letters. It also removes any pencil or carbon markings and any small scratches that the router may make while moving across the wood.
I fill the letters with black craft paint, using a fine brush, carefully. Some people spray their whole board and then either sand or plane off the black on the flat parts. I have not had success trying this, perhaps I need a different paint for that?
I did a second coat of black in the letters and checked for places where it wasn’t solid enough. With wood grain, the paint can sometimes soak in in places and leave small gaps in other places.
Once the black paint has dried, I use an exterior wood finish that soaks into the wood. I used “Deftoil” by Deft which is supposed to “Protect Exterior Woods from the Harmful Effects of Rain and Sun.” This product is brushed on liberally and then left for 30 minutes to penetrate into the wood. You then apply a second coat and wipe after another 20 minutes.
Here’s the finished sign:
Please ask if you have any questions, this is meant to help others try out routing a sign so let me know if you make one.
-- ~Julie~ followyourheartwoodworking.blogspot.ca
11 comments so far
View littlecope's profile
littlecope
3071 posts in 3405 days
#1 posted 09-28-2012 12:18 AM
The Sign came out looking Great Julie, thanks for sharing the process!!
View jumbojack's profile
jumbojack
1673 posts in 2527 days
#2 posted 09-28-2012 12:46 AM
You’ve a very steady hand. You a brain surgeon on the side? Nice work/play!
View HalDougherty's profile
HalDougherty
1820 posts in 3140 days
#3 posted 09-28-2012 01:13 AM
Next time you route a sign, laminated 1/8” thick wood like maple on a 3/4” thick piece of walnut or cherry and you won’t have to paint it.
-- Hal, Tennessee http://www.first285.com
View gfadvm's profile
gfadvm
14940 posts in 2593 days
#4 posted 09-28-2012 01:58 AM
Good blog. I learned a lot here. And your sign turned out great. I like Hal’s suggestion a lot. What a great site this is!
View aselmike's profile
aselmike
10 posts in 2109 days
#5 posted 09-28-2012 02:01 AM
I like your HF router! I just bought one myself.
Great job!
-- Life is Good
View hjt's profile
hjt
822 posts in 3041 days
#6 posted 09-28-2012 02:47 AM
I second that, GFADVIN – this is indeed a great site.
Nice project, kid. you do such nice work. Each time I read your blogs I tell myself… “one day I”m going to ride up to Canada, and work with you for a day or two and learn a bunch. You are one inspiring wood-gal!
-- Harold
View MrHart's profile
MrHart
46 posts in 2186 days
#7 posted 09-28-2012 02:52 AM
Thanks for taking the time to do this maam, I have a sign to make for x-mas.
-- MrHart
View ~Julie~'s profile
~Julie~
607 posts in 2937 days
#8 posted 09-28-2012 07:14 PM
Thanks everyone for the nice comments.
Harold – I may have to visit YOU (as a trip to Florida would be great!), although our leaves are changing now and quite beautiful
Next project coming up… making interior pine doors for the workshop.
Haunched mortise and tenon anyone?
Stay tuned!
View rance's profile
rance
4256 posts in 3063 days
#9 posted 10-01-2012 03:47 PM
Nicely done Julie. Thanks for sharing your techniques.
View hjt's profile
hjt
#10 posted 10-02-2012 04:16 AM
Pam and I would welcome a visit form you and your hubby.
-- Harold
~Julie~
#11 posted 10-02-2012 12:13 PM
Thanks Harold, very kind of you and Pam!
