Making a Side Table my Own Way #3: Clock Table
Blog entry by ~Julie~ posted 08-01-2012 11:37 PM 1427 reads 1 time favorited 0 comments Add to Favorites Watch
« Part 2: Making the parts Part 3 of Making a Side Table my Own Way series Part 4: Compass Table »
Please check out Part 1 and Part 2 of this series to see how I designed and made this table.
After the table was stained, I first put vaseline in spots on the table base and legs. Then I painted with white paint on top, in a bit of a rough way, not being concerned about covering every bit of wood. The vaseline stops the paint from getting through to the wood. Once the paint is dry, I just rub away the vaseline and the stain shows in those parts.
Here is the underside of the table with the Z clips that I often use. These clips are essential to allow for wood movement in the top:
Here’s a couple views of the finished clock table:
-- ~Julie~ followyourheartwoodworking.ca
0 comments so far
