Making a Side Table my Own Way #2: Making the parts
Blog entry by ~Julie~ posted 295 days ago 938 reads 0 times favorited 3 comments Add to Favorites Watch
« Part 1: Designing Part 2 of Making a Side Table my Own Way series Part 3: Clock Table »
I’m trying to make a triangular table base with 3 legs and a circular top.
Okay, to make the base, I cut the apron pieces out of pine at 60 degrees:
The ends are such that one end overlaps the one beside it, which I’m really not sure how to explain other than that and each end is different, with one going past the adjacent piece. Perhaps the photo will show it:
In order to have the legs show their “rolls”
I will cut a groove in each apron piece at a point which will allow the leg to show itself below the apron. So the groove already in the top of the leg will line up with the bottom of the apron.
Inside the groove will sit triangular pieces of plywood that the legs will be screwed into:
This is the bottom of the apron, so, each leg will sit on the triangle and that allows more of the leg to show than if it sat directly on the bottom of the table top.
Here’s the apron upright, you can also see the grooves put in to hold the Z clips that I use to attach the table top:
Everything was glued together, not so easy to do, because of the angles, but the plywood triangles were a tight fit and they helped hold things together. I also used a few finishing nails at each vertex.
The legs were then screwed in to the plywood triangles and I put a quick coat of stain (using my steel wool and vinegar mix) over the whole base:
I’ll show the finished table in my next post!
-- ~Julie~ followyourheartwoodworking.blogspot.ca
3 comments so far
View gfadvm's profile
gfadvm
6635 posts in 859 days
#1 posted 295 days ago
Cool design and looks reasonably easy to build? Can’t wait to see it with the top on.
View BertFlores58's profile
BertFlores58
1530 posts in 1091 days
#2 posted 295 days ago
Hi Julie,
Oh.. I never thought of doing it that way which is simple and easy to do. Arbor is reinforced with the triangular bracket that will also hold the leg. What a great idea!
-- Bert
View Joe Lyddon's profile
Joe Lyddon
6393 posts in 2221 days
#3 posted 295 days ago
Nice Heart you’re following!
COOL design…
Thank you for sharing!
