Router Table by Julie #3: starting the base
Blog entry by ~Julie~ posted 02-16-2011 07:59 PM 1226 reads 1 time favorited 4 comments Add to Favorites Watch
« Part 2: making the top Part 3 of Router Table by Julie series Part 4: making the sides and back »
I’m designing my router table so that it fits with my router and accessories. My Hitachi router will hang upside down on the right hand side. It will need clearance around it for my access to raise and lower it and also for bit changes which I usually do by popping out the whole base and sitting the router on the top of the table.
I also have a small laminate trimmer type router that I usually have attached to a large 12” x 18” plexi base. I use it mostly for routering out designs, so to be able to keep it inside the router table, ready to go, will be helpful. So, the left side will need an opening wide enough to allow that base to sit inside.
The top is 37 3/4” x 23 3/4” and the base needs to sit inside that so that there is an overhang for me to clamp fences to. Also consideration has to be to allow the top frame I made to sit firmly on the base at the correct spot without interfering with the router hanging there.
So, the right hand side will be larger than the left, with the right opening about 15 1/2” wide to hold the Hitachi and the left side only needing to be about 14” wide. The inside depth will be about 18 1/2” to allow that small router to sit inside. A “center” divider will not really be in the center. I like my table high, so I’m not bent over it. I have to take into account the height of the casters I bought from Lee Valley, plus the height of the top, it will be about 38” high.
As I said in my first post HERE, I want my table to match my shop cabinets. I will make an interior box from plywood and then surround it with flat panel framed sides and back. The box will just be on the bottom half, with the center divider going up to the top. (When I read this it sounds confusing, for which I apologize, I do think the photos will explain better than my words)
I’m using 3/4” plywood for the bottom and 1/2” for the sides and the center shelf and dividers. A dado is made for the side to sit into the top and bottom piece.
The lower “center” will be two 1/2” ply pieces glued together for strength as well as for a place for the doors and drawers to rest against. It will sit in a dado. The upper center is first screwed through from the dado underneath before the bottom piece is glued in.
The base is then glued and clamped together.
Here it is ready to be covered by the outer prettier pieces!
...to be continued…
-- ~Julie~ followyourheartwoodworking.blogspot.ca
4 comments so far
View MayflowerDescendant's profile
MayflowerDescendant
414 posts in 2787 days
#1 posted 02-16-2011 08:46 PM
Making good progress. Looking forward to your next milestone / update. Play safe.
-- Glen - Vancouver, British Columbia, Canada
View pintodeluxe's profile
pintodeluxe
5661 posts in 2813 days
#2 posted 02-16-2011 10:24 PM
I remember being annoyed with Norm Abrams one day as I watched his show on how to build your own router table. He walked over to his router table to begin cutting parts—- wait a minute… I thought this show was for people who didn’t have a router table yet!
Now that I do, I know it is essential in the shop.
Best of luck with your project.
View Rob200's profile
Rob200
313 posts in 3169 days
#3 posted 02-17-2011 12:59 AM
getting a good start
-- Robert Laddusaw and no I am not smarter then a fifth grader ( and no I canot spell so if it is a problem don't read it ))
View FaTToaD's profile
FaTToaD
394 posts in 3141 days
#4 posted 02-17-2011 07:52 PM
Good job so far, I really like your approach to the router table. I may to borrow some ideas frm you when I rebuild mine. Keep up the good work.
-- David
