Workshop Build #19: Cupboards on cleats (part 2 of 3)
Blog entry by ~Julie~ posted 06-07-2010 02:47 PM 6036 reads 3 times favorited 6 comments Add to Favorites Watch
« Part 18: Cupboards on cleats (part 1 of 3) Part 19 of Workshop Build series Part 20: Cupboards on cleats (part 3 of 3) »
To continue the cupboard building, the 7 parts of the sides are glued together:
Here are all four sides, for the two cupboards, propped up against the workshop wall:
To accept the back piece, a 1/4” rabbet is run down the back of the stile:
The top and bottom are to be 1/2” plywood, so a 1/4” wide dado is cut 1/4” down from the top and bottom of each side piece:
A 14” wide dado is also cut in the center of the middle rail to accept the center fixed shelf:
The top and bottom plywood pieces are rabbeted on each end to fit into the dado cut in the sides. There is also a rabbet along the back edge to allow the plywood back to sit into the top and bottom:
The cabinet box is glued up with the top, bottom and middle shelf plywood sitting 1/4” back from the front to allow for a solid front edging to cover the plywood layers:
One glued up box without the back yet attached:
The doors are glued up with a top and bottom rail and stile on each side with plexiglass as the panel. Here are all four doors with a few coats of wipe-on polyurethane:
A top view of the joints in the doors:
...to be continued…
-- ~Julie~ followyourheartwoodworking.blogspot.ca
6 comments so far
View hooky's profile
hooky
365 posts in 3284 days
#1 posted 06-07-2010 03:39 PM
cool looking doors
Hooky
-- Happiness is a way of travel , not a destination (Roy Goodman)
117063 posts in 3542 days
#2 posted 06-07-2010 04:56 PM
Good job on the Doors Julie
Beginningwoodworker
13345 posts in 3638 days
#3 posted 06-07-2010 05:10 PM
Nice job on the doors.
View ratchet's profile
ratchet
1391 posts in 3752 days
#4 posted 06-08-2010 08:42 PM
Looks like its really coming together nicely. Any twist/movement on the doors after glue up?
View hjt's profile
hjt
826 posts in 3103 days
#5 posted 06-09-2010 10:14 PM
Julie – just how long have you been into wood working? You do such a good job. Each project I’ve seen is so inspiring. Is this a hobby or profession? I hope to get there some day, but at this time of my life, I simply put the “rough” in “rough carpentry!” Measure 4, 5 times, cut once… buy more lumber. Looking forward to the next installment.
-- Harold
View ~Julie~'s profile
~Julie~
607 posts in 2999 days
#6 posted 06-10-2010 12:47 AM
Hi Ratchet
The doors haven’t twisted… yet. Do you think they might? I did put some glue in the slots with the plexi.
Hi Harold
Thanks for the kind words. I am trying hard to make this into a profession, but the buyers haven’t found me yet!
