Eye Carving Techniques
Blog entry by Eli Adamit posted 1243 days ago 1184 reads 1 time favorited 4 comments Add to Favorites Watch
I was asked about carving eyes in my last project shown http://lumberjocks.com/projects/26334 and answered with a small lesson, It was after most of the members who are interested see already the project and the comment. I assume that more people are interested in this subject so I send it in the blog.
I was asked: “On the first side shown, the side with just the head, how did you do the eyes, if you don’t mind sharing. Mostly on carved eyes, I see them carved inward to use shadow to darken the center of the eye, but the eyes on this appear to shine and sparkle like real eyes.”
My answer was:
I have no problem to share my knowledge and I would like to take this opportunity to credit my master Hans Kantor, in whose studio in Tel Aviv I learnt.
I used 3 different methods to carve an eye:
A. Please look at my previous project called “Moishale”, http://lumberjocks.com/projects/17322 in this case I carved the cornea/ iris – the colored area in the eye by carving the cornea area 1 millimeter deeper and drilled a hole to represent the pupil where the shadow makes it dark (by the way one of Moishale’s eye is blinking)
B. Please look at my previous project called “The prayer”, http://lumberjocks.com/projects/17593 in this case I drilled the cornea area and left the pupil at the same height level as the eyeball. The result is that the cornea is black by the shadow and the pupil is bright like the color of the wood.
C. The anatomical shape of the pupil is circle, but when you stay at a room with several source of light you don’t see the pupil – you see the reflection of the light sources with a shape of something between a rectangle and Banana. So in this project – “Inside as Outside”, I worked as in method B – drilled the cornea and left the reflection of the light sources at the same height level as the eyeball. The result is that the cornea is black by the shadow and the reflection of the light sources is bright like the color of the wood.
-- Eli Adamit, Israel
4 comments so far
View Jordan's profile
Jordan
1336 posts in 1322 days
#1 posted 1242 days ago
I have been looking at your projects – BRAVO! They are really good and you make use of a lot of variety of wood.
-- http://www.jordanstraker.com
TopamaxSurvivor
13179 posts in 1873 days
#2 posted 1242 days ago
Great blog. How do you “I drilled the cornea area and left the pupil at the same height level as the eyeball”? Seems like the pupil wold be hard to leave when drilling the area around it??
-- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence
89134 posts in 1775 days
#3 posted 1242 days ago
Your projects looks good to me
View Eli Adamit's profile
Eli Adamit
333 posts in 1487 days
#4 posted 1242 days ago
Thank you Jordan and Jim for your comments.
Hi Bob, you are right, it is very difficult to leave the pupil staying without damage or break it. Please take in account that in the project “inside as Outside” (first one mentioned above), the most narrow place to drill was about 1millimeter. At the beginning I use a drill with a diameter less than half of the hole needed, than I use a “Dremel” with a flexi –wire equipped with deferent accessories in order to enlarge the hole to the shape I planned. Some of the accessories are covered with diamonds powder, some time I use scalpels also (for the narrow places and for the finish.
