Greene and Greene dining table
Blog entry by edward60 posted 06-07-2016 12:57 PM 1085 reads 3 times favorited 13 comments Add to Favorites Watch
I want to make this table for a long time. But I had not self-reliance for this project. And some time ago I decided to make it. I used for this table sapele, padauk, wenge and ebony for plugs and splines.First I glued top of padauk. The sizes top 70”x47”x1 1/2”. I made template from veener and routing edge of the top.
Then I routing edge with router DeWalt
Then I made sapele edges with another temmplates
For joint top and edges I routing groove for the biscuit joint.
Gluing edges to the top
Making square holes for ebony plugs.
Routing grooves for ebony splines on the edges
Gluing ebony splines
For comfortable work I glued different sand paper on the table
After making ebony plugs gluing its into edges
Shaping ebony splines
Making template for the routing pieces and then routing its
First assembly legs
Making bases of the legs
Then assemly all detailles
Routing legs with templates and making square holes
Gluing decorative elements from wenge
Gluing left and right sides of the base
marking out the base on the top
making elements for the support base and top
Assembly top and base
Finihing . First stained Varathane gel stain
Then finishing with special hard-wax oil
I used this finishing materials
From the bottom of the base I used simple plastic elements.
Finishing with beeswax
And resullt – table in the kitchen
Thank you for your time
13 comments so far
116815 posts in 3453 days
#1 posted 06-07-2016 02:37 PM
This a beautiful table Edward with wonderful details,lots of great workmanship went into this build,
I do wonder about the cross grain banding across the end of the table,if it’s glued on that may be a real problem with wood movement.
View robscastle's profile
robscastle
4736 posts in 2080 days
#2 posted 06-07-2016 02:45 PM
Now thats what I call a blog!
Your ability to duplicate the japanese wood masters skills is impressive.
They certainly produced some complex joinery, I guess at the time out of necessity.
A question the brass inlay material you used in the center piece and how did you do it?
-- Regards Robert
View CharlesNeil's profile
CharlesNeil
2178 posts in 3746 days
#3 posted 06-07-2016 03:06 PM
I am with A1Jim , beautiful work, but I am not seeing any provision for expansion and contraction
View edward60's profile
edward60
142 posts in 1799 days
#4 posted 06-07-2016 05:08 PM
Thanks for the comments. I made special crosspiece and routing long groove for the support of top to base.
This way ensure sliding support top for base and stave off danger expansion and contraction.
edward60
#5 posted 06-07-2016 05:17 PM
To Robscastle. When I made my Greene and Greene bed I ordered lasercut brass elements for the inlay furniture. I used drawing Harvey Ellis . The groove into wood pieces I ordered CNC routing. Then I glued brass elements into wood with epoxy.
#6 posted 06-07-2016 05:34 PM
Edward
you are referring to the apron of the table that’s a good practice to allow wood movement but what I’m talking about is the banding on the edge of the top being a problem for wood movement.
This part
View dalepage's profile
dalepage
320 posts in 716 days
#7 posted 06-07-2016 05:40 PM
Absolutely first rate, Edward. I believe you’re up there with Darrell Peart and Dale Barnard.
Thanks for taking the time to show us.
Dale Edward Page
-- Dale
edward60
#8 posted 06-07-2016 05:59 PM
I saw this construction of the top in ” Arts & Crafts Furniture Spring 2004 ” Issu. The border of the top consist of many pieces , each of its more than enough flexible.Time will tell.
#9 posted 06-07-2016 06:14 PM
If you only glued one side of the biscuits then you will be fine,again this is a beautiful table with very fine craftsmanship.
I really like it.
edward60
#10 posted 06-07-2016 06:18 PM
Thank you for the comments!
View htl's profile
htl
3499 posts in 1035 days
#11 posted 06-07-2016 06:18 PM
Out standing!!!
Love the style and the workmanship.
-- Learn More About Making Wooden Models. An Index Of My Model making Blogs. http://lumberjocks.com/htl/blog/116729
View pottz's profile
pottz
2444 posts in 860 days
#12 posted 04-18-2017 09:32 PM
im a little late commenting on this i guess i missed it the first time,cant believe this only got 809 hits,having done some g&g i know how much skill and work went into this table.your work is absolutly amazing quality,i cant say enough.
View Arlin Eastman's profile
Arlin Eastman
4083 posts in 2437 days
#13 posted 04-18-2017 10:10 PM
Greene & Greene is my favorite and you did a wonderful job at it. :)
-- Please help me help other Vets click..> http://www.gofundme.com/m1abko.....It is always the right time, to do the right thing.
