I have tried a few different methods over the last few months to flatten blades. Here is my go-to method for flattening the back of a new blade.
Adhere some sandpaper to a flat surface. I prefer 3M super77 and a granite surface plate for the substrate.
Use 60-80g until you have a uniform scratch pattern. I prefer Norton 3X 80g at this phase. It is a fast cutter and the paper is thick, so it is easy to install and remove from the granite.
Next comes the 220g w/d. Generally I can get away with using it dry. Again, go for a uniform scratch pattern. I typically try to rotate 90 degrees from the previous pattern, so I know when I have removed all previous scratches.
Onto 400g w/d. Again, remove all previous scratches. I will start to do random motion at this point and lighter pressure once the 220g scratches are worked out. At this point you will begin to pick up a mirror finish.
Next comes 1000g w/d. You know the routine. Remove the scratches. At this time you will have a decent mirror polish going. It is about equivalent to my hard black Arkansas stone.
At this point I will go back and work over the primary bevel. On a new Hock blade or a previously prepped blade I usually can go to the 400 and back to 1000g.
Black Arkansas back, secondary bevel, then strop using green rouge.
Going freehand and by this routine doesn’t give as pretty of an edge as going up through 8000g waterstones using an eclipse jig. But you know it is pretty liberating to ditch the training wheels. I have noticed no decline in cut quality or sharpness of the finished blade. This method is also fairly easy to apply to heavily cambered blades, just add a wrist roll to the regime.
At the end of the day I still need more practice. But I am looking forward to the day that I don’t feel attached to a sharpening jig.
-- Doug, woodworking in Alabama
2 comments so far
Beginningwoodworker
home | projects | blog
4123 posts in 566 days
posted 306 days ago
Nice work, Doug.
-- CJIII Future cabinetmaker
dsb1829
369 posts in 520 days
posted 306 days ago
thanks cj
