Took about 3 hours this afternoon. I am going to close out this series. Yes, still have a few more items that I need to do like seal the top and drill some more dog holes. But, by in large, the bench is complete.
First item of the day, hand plane the legs, vise mount, and apron flush. Minor issue, this bench is getting heavy. I managed to get it down without much strife. I went to pick the thing back up when done and failed. Took 2 more attempts to right this beast. Amazingly enough I have managed to move this bench around without assistance through the entire build. But gravity almost won today ;-)
So I ran the block plane over the legs to flush them up and remove the glue squeeze-out. I then used the no608 to run everything flush. I will use that term lightly. It isn’t perfect, but it will do.
My biggest flaw:
Yep, ended up with one of the feet off by over 1/4in. Oh well, call it a learning experience and move on. I may fix it at some point but the only real reason to do so is for vanity-sake.
Here is what it should look like, not a prefect mate but much better…
I added a t-nut and 3/8in bolt for a leveler on the rear foot. Nothing fancy, just makes life easier with an uneven garage floor. So now I can tripod and then use this screw to locate the 4th foot.
The twin screw is back together. I flushed the top with the bench top. Here you can see the mounting blocks and leg flushed as well as the carrier pins.
The end vise:
I think I will make an oak chock for it out of the mistake chock from the twin screw. Maybe later, I am going to use this one for a bit longer first. Here is a birdseye view of the end vise dog holes stretching the entire bench. I can handle up to just over 9ft boards between the dog holes, that should hold me for now.
Remember that sand used for the top lamination??
That is mass that we can use. Put it in tubs so it doesn’t continue to leak sand in the shop. Then put those tubes on the shelf.
Instant 200+lb to the bench. It is pretty good without it, but that mass really anchors the bench and gives it a rock-solid feel. Only dissadvantage I see is that you have to remove the tubs to move the bench around the shop. No biggie.
Time log: 41 hours
-- Doug, woodworking in Alabama
10 comments so far
3fingerpat
home | projects | blog
905 posts in 560 days
posted 314 days ago
Excellent series, thanks for sharing all your hard work and efforts. The bench looks great, now go take a rest before you start to enjoy the fruits of your labor ;o)
Beginningwoodworker
4101 posts in 565 days
posted 314 days ago
Nice workbench!
-- CJIII Future cabinetmaker
JustBuildStuff
5 posts in 320 days
posted 314 days ago
The bench looks incredible and I am sure many more incredible projects will be built upon it.
Thanks for taking the time to post about it.
-- Kurtis, North Dakota http://justbuildstuff.com/
Tomcat1066
776 posts in 688 days
posted 314 days ago
Good job Doug! Thanks for sharing this with us :D
-- "Give me your poor tools, your tired steel, your huddled masses of rust." Yep, I ripped off the Statue of Liberty. That's how I roll!
dsb1829
369 posts in 520 days
posted 314 days ago
Hey guys, thanks for the kind words. I am glad that you were able to follow along on this project. It was fun to be able to share the victories and the errors associated with the build.
I will be sure to post the final glamour shots over in the projects forum once I get a couple coats of shellac on the thing.
PurpLev
2732 posts in 541 days
posted 314 days ago
nice bench!
you can always replace those sand-bags-in-crates with tool drawers later on which will anchor the bench with it’s weight – and also make great use of that space under the bench – plus, you’ll have your hand/other tools close by when needed….
dsb1829
posted 313 days ago
I will get a tool cabinet of sorts under there eventually. For now I gotta get back to working on furniture. Thanks for reading along.
Quentin
43 posts in 1038 days
posted 311 days ago
Nice blog! I loved reading it and I’m very jealous of your workbench!
trucker12349
88 posts in 377 days
posted 310 days ago
Why not replace the sand bags with a few bags of kitty litter so you have a spill material handy. I recently had someone spill a half can of stain and used the litter to clean it up. I had a long talk with me, myself, and I, but no one will own up to the spill, lol
dsb1829
posted 310 days ago
You really should do something about those shady caracters horsing around in your shop :-)
Kitty litter cleanup storage. Hmmm, not a bad idea. I picked up the sand to help with the lamination of the top, so I already had it. That’s the only reason I used it. I don’t really need the extra mass, but since it is paid for and would just be taking up room around the house somewhere I put it to use.
