I had to take a couple of days off for Holiday travel. I got back at the bench yesterday for about 6 hours and batched out the dog holes and lower shelf.
I am not overly thrilled with how the dog holes worked out. In the end I used an Irwin boring bit and this jig.
I found that using just one clamp allowed the board to wiggle some as the bit drove in. Doing it this way the second and third clamps secure the board better. A backing board is necessary.
or you will get blowout at the bottom…
Overall the boring bit didn’t leave a great finish and it was constantly clogging. It also wobbled a bit due to runout. I don’t think the bit was ever intended for nice work. Forstner bits are also pretty prone to clogging. I also found the forstner very hard to keep aligned. I think if I were to do it on a nicer bench I would use the router for the top inch and then a standard brad point bit to get full depth. I went cheap. It did work out, but again it was another learning experience.
I added a temporary stretcher to reduce racking so that I could use the bench to surface the boards for the bottom shelf.
This worked fairly well. racking was there, but not so bad that it affected my work.
The shelf is constructed with but joints. Since it is captured between the legs there isn’t really a need for a stronger joint. Time will tell if that assumption was correct. As it is the bench is knock-down, so I could easily build a new shelf if it came to that.
I also had a scrap laying around that I mitered to fit on the diagonal. I don’t think it does much, but I had the scrap and extra bracing never hurt anyone.
To finish up I moved the temporary stretcher to the rear and bolted it up.
Time log:24.5hr so far
Next up front twin screw construction and laminating up the front of the legs to flush them to the front apron.
-- Doug, woodworking in Alabama
6 comments so far
SPalm
home | projects | blog
948 posts in 777 days
posted 325 days ago
Sweet. It is really looking good.
I went through the dog hole thing this summer. It can be nerve racking. I bought a 3/4” spiral upcut router bit ($$$) and it cut like butter, but did not go all the way through. So I had to finsh drill with a bit such as yours. I admit, I have not finished all of them yet.
Amamzing how the time goes, huh?
Steve
thetimberkid
1944 posts in 598 days
posted 325 days ago
Looking good!
Thanks for the post
Callum
Derek Lyons
263 posts in 463 days
posted 325 days ago
Twenty four hours – shoot, you’ve got a whole day left in that weekend! :) :)
-- Derek, Bremerton WA --
Beginningwoodworker
4173 posts in 568 days
posted 324 days ago
Nice progress Doug.
-- CJIII Future cabinetmaker
Tomcat1066
776 posts in 691 days
posted 324 days ago
Looks good Doug. I can’t wait to see the finished product, which can’t be to far away, can it? ;)
-- "Give me your poor tools, your tired steel, your huddled masses of rust." Yep, I ripped off the Statue of Liberty. That's how I roll!
dsb1829
369 posts in 522 days
posted 323 days ago
Hey guys, thanks for the comments. I am thinking that this bench is more like a 2 weekend project :)
Design as you go is a bit time consuming. With a plan in hand things would have gone faster. Also pre-milling all lumber to dimension would have been much less time than the mill as you go approach that I used.
Hey Steve, where did you find a 3/4in spiral upcut bit? I did a quick look at the usual suspects (rockler, woodcraft, mlcs, eagle) and didn’t stumble on anything.
