Chairmaking at the Appalachian Center for Craft #5: Day 5
Blog entry by doorslammer posted 07-16-2010 04:07 AM 1087 reads 0 times favorited 1 comment Add to Favorites Watch
« Part 4: Day 4 Part 5 of Chairmaking at the Appalachian Center for Craft series Part 6: Day 6 The final day »
The first order of business for today was cutting and fitting the back rail. After getting the other three sides clamped together in a reasonably sturdy assembly, I took a rough measurement and cut the piece long and began sneaking up on the fit until I thought it was reasonably close then I cut the mortises in the ends with the Domino.
Then came the always stressful glue up. Everything went together pretty well and I was reasonably pleased with all the joints.
Next I unclamped my bent lamination back rest and began to fit it. I the arc of the lamination did not meet the legs perfectly so I had to use my block plane and bevel the outer edges of the top of the legs.
After getting things fitting pretty good I marked, drilled and counter sunk holes for the T-nuts and screws that will hold the back rest on. I had to trim the the bolts so they didn’t protrude from the back rest and poke through my outer veneer layer during final assembly.
Once this was complete I went back to the lamination jig to glue on the final layer that will cover the T-nuts.
Tomorrow is the last day of class. I’m going to get my back rest cut to shape and sanded. Probably won’t get to a seat this week, but the instructor had one he made so I borrowed it to see how it looked.
-- Aaron in TN -http://www.amwellsfurniture.com
1 comment so far
View Woodwrecker's profile
Woodwrecker
4153 posts in 3597 days
#1 posted 07-16-2010 07:24 AM
Looking good Aaron!
Some really smart adjustments to fit everything up nicely.
That is going to be one cool chair.
-- Eric, central Florida / Utor praemia operibus duris
