Around the Shop #21: Butcher Block restoration.
Blog entry by Don W posted 10-19-2013 12:59 PM 2384 reads 0 times favorited 20 comments Add to Favorites Watch
« Part 20: The Oak Table Restoration. Let's see where it goes. Part 21 of Around the Shop series Part 22: Walker Turner Lathe Restore. Fighting to the bitter end. »
Yesterday, on the way home from running some errands my wife and I stopped at a new local antique mall. The official opening hasn’t happened yet, but there was an open sign, so we pulled in. In a “fix it up yourself” section we found this butcher block top at an extremely reasonable price.
The top itself is in really good shape. It’s got just enough cracks to give it a nice patina, without effecting the integrity and it’s a bit over 14” thick. The big issue…..no legs.
So the question. I’ve been doing some research, but can’t find the answer. It looks from these pictures,
that there was some kind of metal (maybe wood?) bracket that helped hold the tenons of the legs in place. If anyone has an example of this bracket, or thoughts what it looks like, comments are appreciated.
So off to the wood pile this morning. I have a pile of bottom cuts off the saw mill. When you get to the last cut of the log, it will be the size of whatever is left. So I often leave some thicker pieces, for moments like these. And low and behold, there is a piece of 3 1/2” x 7 maple, plenty long enough for the 4 legs (or so I hope).
As always, any advice is appreciated.It may sit in the shop for a few, but it also may get shoved to the top of the to-do list. I hear it calling my name. If it wasn’t for these damn leaves!
20 comments so far
View JoeinGa's profile
JoeinGa
7733 posts in 1914 days
#1 posted 10-19-2013 01:07 PM
If it was metal, was probably a big version of this
View Don W's profile
Don W
18606 posts in 2474 days
#2 posted 10-19-2013 01:12 PM
I thought about that Joe, but I can’t figure out why. Would it just be to reinforce the wood from sideways stress? So a piece of 1\2” steel with a hole in it would work? Most of the butcher blocks I’ve seen is just wood on wood.
View ShaneA's profile
ShaneA
6889 posts in 2505 days
#3 posted 10-19-2013 02:00 PM
Whoa, bet it is heavy. The ones I have seen (like 3) have always had wood legs. Similar to a table, throw in a stretcher and it should be damn stable. Heck I might even consider squaring out the round holes for easier tenon fit. Just because I am not real big into turned legs. Look forward to seeing what you come up with.
View WayneC's profile
WayneC
13751 posts in 4004 days
#4 posted 10-19-2013 02:07 PM
It might just be round legs with tenons. There is a leg photo in this page that has square legs with round tenons that looks similar to me…
http://www.nerdylorrin.net/jerry/r+j/MyButcherBlk/ButcherBlk.html
View poopiekat's profile
poopiekat
4325 posts in 3641 days
#5 posted 10-19-2013 02:17 PM
I agree with you, Don, about most butcher block legs being just wood-on-wood, but I found this image in photobucket:
I’ll look for some better images…
Don W
#6 posted 10-19-2013 03:07 PM
I’ll be honest, I never thought of the possible that the legs themselves might have been metal. That’s definitely a possibility. The new legs will most certainly be maple and mostly square. I could turn them, but both my wife and I like the square look. Maybe a taper at the bottom.
I agree the round tenon holes may become square.
thanks guys! Its helping so far. Certainly some new thought processes.
View Bluepine38's profile
Bluepine38
3379 posts in 2992 days
#7 posted 10-19-2013 04:35 PM
Great looking start for a project, just one caution, decide if you want to redo the top before starting on the
legs. After using a router jig to resurface some cutting blocks a few years ago, the shop had to add some
contrasting feet to the legs to get the surface of the block back to a comfortable working height.
View Druid's profile
Druid
1719 posts in 2702 days
#8 posted 10-19-2013 11:37 PM
Hi, I think that Joe might be on the right track. Many of these blocks had to sit on floors that were not quite level, but the working surface had to be stable. So, picture the type of flange that Joe showed, and the legs (sections of pipe to match the flange thread) would have a threaded section a couple of inches long. This permitted the legs to be adjustable, and if necessary, protrude through the flange into the recess that your photos show. With this type of adjustment, the block could be relocated and leveled very easily. Wooden legs would not be quite as versatile. The bottom end of the pipe legs would have had either a pipe cap or a rubber boot to prevent the pipe from damaging the floor.
Of course, if you still want the square wooden look, you can make wooden sleeves to fit over the pipes, and leave a gap at the top to permit leveling adjustment.
Hope this helps.
-- John, British Columbia, Canada
View AnthonyReed's profile
AnthonyReed
9587 posts in 2347 days
#9 posted 10-20-2013 04:43 PM
It will be fun to see where you end up on this.
John’s explanation seems on the money.
-- ~Tony
View Dave's profile
Dave
11426 posts in 2747 days
#10 posted 10-22-2013 12:16 PM
Nice find and I love the forensics on the mystery.
Don W
#11 posted 10-26-2013 09:26 PM
much progress…...
The prototype submitted for approval.
Approval so, on with the show.
And as I left the shop tonight.
AnthonyReed
#12 posted 10-27-2013 01:44 AM
Too slick! That looks great.
-- ~Tony
poopiekat
#13 posted 10-27-2013 04:17 PM
Don, Tell us how you flip it over, back onto its feet! Looks like it will be a lot of side pressure, as it gets rolled over. Knowing you, you’ve got a plan in mind for this…
Don W
#14 posted 10-27-2013 04:32 PM
I managed to walk it back onto 1 saw bench. Then I tipped it sideways on the other saw bench. The saw bench is just higher enough that I could lay it down, making sure the edge stayed on the second bench. Once the two outside legs were on the floor I just slid the bench out from under it.
pictures later standing upright.
ShaneA
#15 posted 10-27-2013 05:02 PM
Can’t quite confirm, and I think my eyes are playing tricks on me…but do the legs have a bit of splay to them? Are you going w/o stretchers?
