dw's shop tips #4: Remove a rusted nut on all threads.
Blog entry by Don W posted 09-16-2013 01:01 AM 1461 reads 0 times favorited 13 comments Add to Favorites Watch
« Part 3: Pilot hole without a drill bit. Part 4 of dw's shop tips series no next part
I had to remove the adjuster on a threaded post from a #71. Here is how I did it. The bolt was rusted solid and would not move.
I had soaked it in penetrating oil for a while (almost a week) but it still didn’t want to move. I could heat it, but I’d still have to hold on the threads. So I cut a piece of aluminum flashing.
I folded the flashing and clamped it in the vice. The aluminum will not hurt the threads but will hold it tight.
This is a knurled nut so another piece of aluminum to protect it from the vice grips.
A few twist.
Oil it up and reassemble
Sorry for the upside down pictures. I’m not sure what that’s about.
13 comments so far
View mafe's profile
mafe
11741 posts in 3211 days
#1 posted 09-16-2013 01:07 AM
Clever, this one I will remember.
Best thoughts,
Mads
View Woodknack's profile
Woodknack
12341 posts in 2502 days
#2 posted 09-16-2013 01:17 AM
I had one of these… spun 2 nuts on the bottom, tightened them together, clamped it and spun the adjuster off.
View Don W's profile
Don W
18946 posts in 2689 days
#3 posted 09-16-2013 01:21 AM
I’ve done that as well Rick, but some of these Stanley threads don’t have nuts :-)
Woodknack
#4 posted 09-16-2013 02:09 AM
Yeah mine was LH and I for some odd reason happened to have 2 LH nuts the right size.
Smitty_Cabinetshop
15522 posts in 2740 days
#5 posted 09-16-2013 02:35 AM
I like the aluminum tip. Most appreciated, Don Yoda.
View yuridichesky's profile
yuridichesky
624 posts in 2085 days
#6 posted 09-16-2013 05:30 AM
I second that aluminum trick. Here’s how I upgraded my machinist vise right after purchasing:
I can easily slide those straps off the jaws when I need, but most of the time they’re on the jaws.
-- Yuri (10x4 -- yeah, that's my tiny shop!)
yuridichesky
#7 posted 09-16-2013 05:34 AM
And the upside down pictures could be due to current phone orientation (the sensor is not always correct) in case if you took those pics on the phone.
View JoeinGa's profile
JoeinGa
7739 posts in 2129 days
#8 posted 09-16-2013 07:24 PM
Similar to Yuri’s picture I have a set of aluminum jaw inserts for my vice. I also have a set of rubber and one of some kind of hard fiber. They’re held in place with 2 magnets on each side and come in VERY handy some days.
View Howie's profile
Howie
2656 posts in 3045 days
#9 posted 09-16-2013 07:39 PM
Now there is a worthwile piece of advice. Thanks for the tip.
-- Life is good.
View bluekingfisher's profile
bluekingfisher
1250 posts in 3101 days
#10 posted 09-17-2013 11:08 AM
where there’s a will there’s a way.
I second what turichesky says although I use lead flashing on my vice jaws. The lead being softer bites into the work a little more pproviding more holding power. They don’t last as long but I only use thenm when needs be
-- No one plans to fail, they just, just fail to plan
View AnthonyReed's profile
AnthonyReed
9968 posts in 2562 days
#11 posted 09-17-2013 02:50 PM
Thank you Don.
-- ~Tony
View Mauricio's profile
Mauricio
7144 posts in 3273 days
#12 posted 09-19-2013 12:47 PM
Great tip!
View oltexasboy's profile
oltexasboy
11 posts in 2293 days
#13 posted 09-23-2013 07:07 PM
Hey Don,thanks again for the great planes. I was a heavy equipment mech for 45 years and the best penetrating oil I have ever used is a product called “S’OK” It is sold now by a Co. in Paletine Tx. You might order a little can ,take my word for it ,it will be the best thing since sliced bread for rust.
http://www.shamrockspecialties.net/contact.php
