Around the Shop #19: Display case. The request is in.
Blog entry by Don W posted 07-23-2013 04:25 AM 1960 reads 0 times favorited 18 comments Add to Favorites Watch
« Part 18: A pine benchtop Part 19 of Around the Shop series Part 20: The Oak Table Restoration. Let's see where it goes. »
So my wife has been putting together some pieces for a display case for some of her old crocks. We’ve found the pieces, now the fun begins.
So here is the display part. It doesn’t have a bottom, so the table top will be the bottom of the display. It will have one more shelf added.
The idea is to make a bench or table that it sits on. Here are the future legs.
Here is what I have to work with.
The Idea is something like this. I’ll remove the door knob. The make a cut along the red line. Part A will become the table top.
Part D will be the front of the face frame (or apron), with C and E being cut down for the end frames (or aprons). A back piece will be made from dimensional lumber since it will be against a wall and never seen.
I could dowel the frame to the legs. If I did a threw tenon, the end would show, and I don’t want that. I could 45 the corners and notch the legs with inside braces. I’m looking for idea’s.
How would you build it?
Thanks for the input.
The Build begins
After getting home from work,
I took a stab on figuring out how this would go together. The first thing I did was took the door completely apart. I managed to find the pins, popped them out and the door was in pieces.
This brought up some old joinery
Next I cut the pieces for the top to size.
I decided to dowel the frame. It seemed easier and less intrusive to the material around it. I made a template so the dowels all drilled the same.
A dry fit showed it was coming out like I had envisioned.
My problem began when I went to grab my dowels. Problem being I didn’t have any. So…....I made some. The 40 mile round trip to Home Depot just wasn’t in my plan.
I like to add a little crimp to my dowels. It help the glue hold and help round them out as well.
Added some additional support
And Glued it all up.
Added some corner brackets
And called it a day
18 comments so far
Smitty_Cabinetshop
15373 posts in 2668 days
#1 posted 07-23-2013 04:35 AM
How much play above and below the turning of the leg pieces?
View Don W's profile
Don W
18788 posts in 2617 days
#2 posted 07-23-2013 04:43 AM
Approx 4”
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 2906 days
#3 posted 07-23-2013 09:09 AM
Interesting Don it looks as if you have given yourself a nice wee challenge
I’m sure it is going to come out great
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
Smitty_Cabinetshop
#4 posted 07-23-2013 11:19 AM
Ouch, that’s not much to work with!
Trying to think stretchers, M&T joinery, but it’s not coming through. Looks like there should be actual feet vs. turning ends that land on the floor directly…
What about a trestle base, with those turnings as pairs on either end?
View AnthonyReed's profile
AnthonyReed
9793 posts in 2490 days
#5 posted 07-23-2013 01:27 PM
A Don / Smitty collaboration will be engaging.
The confidence in you displayed by your wife is fun too. “Here are a few pieces to work with. You know what I am looking for, now go build it.”
I’m looking forward to seeing what you come up with.
-- ~Tony
Don W
#6 posted 07-23-2013 01:36 PM
Stretchers instead of aprons? I didn’t think of that. I’m not sure how that would work, but its another thought line.
I had thought of M&T. It may be one of those, design as you build projects.
Smitty_Cabinetshop
#7 posted 07-23-2013 02:03 PM
This is what I’ve been thinking (thinking not being my particular strong suit…)
There’s still a stretcher (M&T) at the bottom and an apron at the top. Maybe too much going on, but it lateral stability with heavier contents of the cabinet is a concern.
Don W
#8 posted 07-23-2013 02:15 PM
I had a similar thought but not sure I’ll have enough material.
Thanks for that drawing Smitty. Its along the lines of what I’m looking for.
Edit:
Or maybe the bottom bases from oak? Hmmmmm
Don W
#9 posted 07-27-2013 09:25 PM
Some progress added.
Smitty_Cabinetshop
#10 posted 07-28-2013 05:29 AM
I very much like it…
Don W
#11 posted 07-28-2013 12:53 PM
Thanks Smitty. It went together easier than I expected. I would have likes to have done a single support across the bottom instead of the angles but I just didn’t have a piece to do it. This is probably stronger anyhow.
View JayT's profile
JayT
5701 posts in 2261 days
#12 posted 07-28-2013 01:12 PM
Looking good, Don. Very good and creative use of the door pieces.
View terryR's profile
terryR
7194 posts in 2358 days
#13 posted 07-28-2013 01:51 PM
Don, it’s looking great! I certainly don’t have the design skills to offer advise, but I can offer enthusiasm! And thanks for teaching me how to dis-assemble an ancient wooden door!
-- tr ...see one, do one, teach one...
View theoldfart's profile
theoldfart
9760 posts in 2501 days
#14 posted 07-28-2013 02:05 PM
+1 on what Terry said, I see lots of doors out on the tree belt for free, now I can salvage some wood. Got two in my garage now!
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
AnthonyReed
#15 posted 07-28-2013 03:50 PM
Man that looks great.
-- ~Tony
showing 1 through 15 of 18 comments
