Making the dw infills #4: Lets do some tapping and peening.
Blog entry by Don W posted 04-07-2013 12:56 AM 2933 reads 3 times favorited 20 comments Add to Favorites Watch
« Part 3: Part 3 the infill saga Part 4 of Making the dw infills series no next part
So another way to attach the sides is tapping and peening. I thought I’d give it a try on a small smoother. I decided on aluminum sides and hot rolled steel for the sole. The aluminum is 1/8” x 2” and hot the rolled steel is about 3/8” x 1 7/8”. I wanted to use a 1 5/8” block plane iron.
Infill is cherry.
Lever cap is brass.
This time I cut the sole in 2 pieces. I found this technique a lot easier. The I drilled the sides. And tapered them with a reamer.
Next I used the counter sink to give the holes a countersink. I figured between the taper and the countersink, they should tighten up nice.
The holes were the tapped 1/4×20
And the bolts tighten in. I really don’t think it would be necessary to use epoxy, but for the price of a tube of JB Weld, everything got welded.
Here I’m checking the depth to make sure I’m deep enough for the bolts.
bolt heads where cut off.
Then the bolts pened over.
I have about 6 hours in it at this point.
And a quick test run
Day 2
About another 4-5 hours.
I didn’t have a piece of metal for the cap iron (I may eventually just get a thicker iron) so I wound up using an old badly pitted #120 iron. It will be replaced.
The rest of the time was spent shaping the lever cap, making the chip breaker and sanding and finishing the plane.
Thanks for looking.
dw
20 comments so far
View RussellAP's profile
RussellAP
3103 posts in 2162 days
#1 posted 04-07-2013 01:05 AM
Great work Don. You could carve some wooden sides to make it more comfy, looks a little sharp, a good snag could result in getting blood all over your work. That’s a sin.
View Don W's profile
Don W
18564 posts in 2443 days
#2 posted 04-07-2013 01:07 AM
its not finished Russell. Hopefully tomorrow.
View poopiekat's profile
poopiekat
4322 posts in 3610 days
#3 posted 04-07-2013 01:15 AM
Really impressive, Don!
I’m going to make a 3/4” dado plane, but I’m not sure whether it will be in aluminum or wood, and I haven’t found a good idea yet that I can use for the nickers. I’m sort of leaning toward those replacement wheels for copper tubing cutters to scribe and cut ahead of either a chisel or Stanley #45 3/4” cutter. Keep up the good work, sir!
View ShaneA's profile
ShaneA
6881 posts in 2474 days
#4 posted 04-07-2013 01:32 AM
Is it my imagination, or are you cranking these things out in record time? You elves must be tired by now, I am.
RussellAP
#5 posted 04-07-2013 01:39 AM
Shane, he’s in serious danger of becoming a metal worker.
View Mauricio's profile
Mauricio
7139 posts in 3027 days
#6 posted 04-07-2013 04:10 AM
Wow Don, you made this one look even easier than making a wooden Krenov plane!
Poopie, I’m looking forward to seeing that dado plane!
View lysdexic's profile
lysdexic
5238 posts in 2499 days
#7 posted 04-07-2013 12:58 PM
How hard is it to keep everything square? It would be cool to make a dedicated shooting plane with your skill set.
-- "It's only wood. Use it." - Smitty || Instagram - out_of_focus1.618
View Jamie Speirs's profile
Jamie Speirs
4167 posts in 2732 days
#8 posted 04-08-2013 05:55 AM
Don thats a lot of work
However the results are well worth it
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View Brit's profile
Brit
7355 posts in 2719 days
#9 posted 04-08-2013 08:10 PM
I think this one is my favourite Don. I’ve always been partial to little infill smoothers. That’s a nice piece of cherry too. Great work as usual.
-- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
View JayT's profile
JayT
5497 posts in 2087 days
#10 posted 04-08-2013 08:54 PM
OK, infills are growing on me. Nice work, Don.
One question about sizing of the metal parts. With a 3/8 base plate and 1/4 in bolts, that doesn’t leave much metal underneath the spots that were tapped. Could this become a problem down the road if the sole needs re-flattened?
Don W
#11 posted 04-08-2013 11:20 PM
JayT. For anything much larger I’d probably go to 1/2”, but if you raised the threads up just a hair, I don’t think it would be an issue. That’s a lot of flattening by hand. If you think about it, a Stanley sole is only about 1/8” thick.
Thanks Andy.
Mauricio, I wouldn’t say easier than a krenov, but not difficult.
View AnthonyReed's profile
AnthonyReed
9547 posts in 2316 days
#12 posted 04-09-2013 03:05 PM
Don i know you are a wizard of some type but geez you are pumping these out in such numbers and increasing quality that is boggles the mind.
PK- Would the replacement cutting wheels for the Veritas marking gauges work as knickers?
-- ~Tony
poopiekat
#13 posted 04-09-2013 06:15 PM
Anthony: Hmm, yes I think they would come close…wonder if they’d really shear the grain, or just make an indent? I’ve got so many failed experiments, I’d hate to kill my $30 Veritas gauge just for the wheel; I’d thought of the plumber tubecutters only because they’re cheep at our local junk store…and I’d be machining into the aluminum slabs to fit whatever cutters I end up using… they’d better WORK or back it goes to my metals barrel…I will never be as prolific as our own DonW!
AnthonyReed
#14 posted 04-09-2013 06:20 PM
PK - Replacement cutters are $4.95 @ Lee Valley (#C or #D), no need to kill a gauge.
-- ~Tony
View mafe's profile
mafe
11630 posts in 2965 days
#15 posted 04-10-2013 01:46 PM
Really nice Don.
You have really become a plane creator.
I love your always relaxed approach – I can do that!
Lovely little plane.
Best thoughts,
Mads
