Making the dw infills #3: Part 3 the infill saga
Blog entry by Don W posted 04-03-2013 09:31 PM 2102 reads 1 time favorited 20 comments Add to Favorites Watch
« Part 2: Let's dovetail Part 3 of Making the dw infills series Part 4: Lets do some tapping and peening. »
So making the infill wasn’t so bad. Its so much easier when make a base. When you make the base, its square and true, unlike the inside of the cast vintage planes, so making and addind the base is much easier.
I choose walnut for this, and after some help from my friend over on the HPOYD thread, I decided to ebonize it.
Most of this is just normal woodworking, at least for the first part.
And marking and laying it out,
I decided to make this one in 1 piece. I’m not sure it’s really important and the others I didn’t. I don’t see much difference in the outcome. I used the router to cut it out.
I drilled the center, cut it with a scroll saw and shaped it with some rasps and files.
constant fitting to ensure it was going right.
Once it was formed and sanded, It was time to darken it. I had some issues with the ebonozing. I took some white vinegar and stuck some steel wool in it. After several days nothing had happened. I made sure i was using real steel wool. After some reading and some help from the guys over on the HPOYD thread, I threw some rusty nails in it and put the heat gun to it. If your doing this it is advisable to keep the cap loose and be in a well ventilated area.
Whala
I then gave it several coats of dark walnut danish oil.
Its not ready, but lets try it out anyhow.
ahhh, some sweet shavings
Now to fasten it in. I drilled the side hole just a little smaller than some #12 brass screws, and used a reamer to give it a slight taper, along with a countersink to give the holes a little countersink. I then drove the screws as tight as I could into the countersink. Note, you need slotted screws for this. With Philips head screws, the Philips cut out goes to far down into the shaft.
I then took the grinder to the screws, sanded the sides with my ROS, from 80 grit up through 320, and buffed it out.
The the knob and tote got a couple coats of wipe on poly.
I also realized I didn’t take any pictures of making the cap iron or lever cap, so next plane for sure.
The cap iron is Low-Carbon Steel Rectangular Bar, 1/8” Thick, 2” Width, 2’ Length, drilled and tapped, given a slight bend into the iron, the end ground at an angle and polished up.
Cost calculation:
Steel, $12
Brass, $12
Cap screws $3
Brass screws, $6
about 1 BF of walnut. cost ?
Vinegar $3
Bridge City close out knurled adjuster $5.50
Hock Iron $50
20 comments so far
View JayT's profile
JayT
5674 posts in 2236 days
#1 posted 04-03-2013 09:45 PM
Still loving it. Can’t wait to see how you do the lever cap.
View BTimmons's profile
BTimmons
2303 posts in 2510 days
#2 posted 04-03-2013 09:51 PM
It’s really cool to see this aspect of your work coming along so nicely.
Apart from looking cool, what’s the functional advantage of an infill plane over other types? I imagine that more mass and having the iron fully supported along the underside reduces chatter? I don’t really know the first thing about this variety.
-- Brian Timmons - http://www.BigTWoodworks.com
View Don W's profile
Don W
18754 posts in 2592 days
#3 posted 04-03-2013 10:05 PM
Advantages:
1. its just cool!!
2. Mass. Its heavier.
3. Infills are typically bedded at 50 or 55 degrees. (this one is 50)
4. Steel. A drop means a dent, and maybe some wood damage which is repairable.
5. they are cool!
6. Brass is shiny.
View ShaneA's profile
ShaneA
6956 posts in 2623 days
#4 posted 04-03-2013 10:08 PM
It is very nice Don. Every aspect looks great. Can we get a shot of the base?
Congrats on great plane building, and thanks for giving us insight into the process.
Don W
#5 posted 04-03-2013 10:16 PM
I plan to take some more pictures Shane. It was still a little tacking when I took the last one.
View ksSlim's profile
ksSlim
1276 posts in 2915 days
#6 posted 04-03-2013 11:14 PM
Great looking. I’m curious, about why ebonize walnut?
Did you just want it darker? Recently tried the process on different wood.
Results on my side, OK but not perfect.
-- Sawdust and shavings are therapeutic
Don W
#7 posted 04-03-2013 11:17 PM
I had a piece of walnut that was the right size, and just wanted to try something different. There was not compelling reason really.
Don W
#8 posted 04-03-2013 11:30 PM
Shane to answer your question from the second part, I figure I have some wheres between 30-40 hours in it.
View terryR's profile
terryR
7168 posts in 2333 days
#9 posted 04-03-2013 11:41 PM
WOW! That’s awesome, Don! I love the brass screws through the sides…matches your lever cap nicely.
Each one has out done the previous…gonna be hard to top this one! :)
-- tr ...see one, do one, teach one...
View Tugboater78's profile
Tugboater78
2746 posts in 2216 days
#10 posted 04-04-2013 01:38 AM
Thats purty, pretty sweet that you made your own
-- "....put that handsaw to work and make it earn its keep. - summerfi" <==< JuStiN >==>=->
View lysdexic's profile
lysdexic
5255 posts in 2648 days
#11 posted 04-04-2013 03:56 AM
Don, these infills a very handsome. I am really impressed.
-- "It's only wood. Use it." - Smitty || Instagram - out_of_focus1.618
View bluekingfisher's profile
bluekingfisher
1250 posts in 3004 days
#12 posted 04-04-2013 08:58 AM
Quality work on the plane, one to pass down the generations for sure.
-- No one plans to fail, they just, just fail to plan
View Mauricio's profile
Mauricio
7144 posts in 3176 days
#13 posted 04-04-2013 02:26 PM
I love it Don, amazing work.
So do you think these infills will replace any of your vintage planes for everyday work?
Don W
#14 posted 04-04-2013 02:33 PM
Absolutely.
Mauricio
#15 posted 04-04-2013 02:35 PM
how cool would it be if all your user planes were infills. Talk about plane envy…
