Writing a blog about How to set up a Hand Plane will take a series, because it really depends on what you are trying to do. In other words, a smoother will be different than a jack and so forth, but it even goes further than that. At what stage your planing with your smoother will make a difference also.
So here is a few tips to get you started, and I’m assuming this is for a smoother, so adjust as needed.
- Set the frog far enough ahead so when the blade just starts to cut, it would be difficult to slide a business card through the mouth, but you could probably force it if you had to.
- Set the chip breaker as close to the edge of the iron as your eyes allow, maybe a 1/16” or a smidgen tighter. Make sure it never goes beyond the blade if the blade is a little uneven or cambered. Here is a blog on setting the chip breaker.
- The cap should be as tight as you can make it and still easily move the iron up and down. Start loose and tighten it down until you feel the adjustment start to become harder.
- You always want to start planing with the blade retracted just above the mouth.
- Slowly lower it until its through. Use the lateral adjuster to make it even across the mouth.
-You can slide a thin piece of wood across one side of the iron then the other to make sure its even, or use your eye. As you practice, you will use your eyes more and more. Using your finger tends to cause bloodshed so its not recommended :-)
- As you’re planing, if you see the iron is taking shavings on one side and the other, move the lateral adjuster toward the shavings, or the heavier side.
- Your first swipe should get nothing, but slowing lower the iron until it starts to take a shaving.
- Then just adjust accordingly.
A thin shaving should look like this![]()
- But remember that different wood react differently and you can get thinner or thicker depending on have much smoothing needs to be done.
- If they shaving comes out like sawdust, or you are pushing to hard to get shavings your iron is not sharp.
- If your iron is straight, even and the wood is straight grained, you get a even shavings across the cut, the full width, or almost the full width of the cut.
- The more your iron is sharpened with a camber, the less this will happen. That is often by design so not always a bad thing.
- Always start your stroke with the plane skewed to one side. It makes the cut more of a slicing action and allows a easier cut.
- Practice makes perfect.
Hope it helps
10 comments so far
ksSlim
home | projects | blog
803 posts in 1060 days
#1 posted 102 days ago
Good stuff, keep it coming.
I see a book or a DVD here.
-- Sawdust and shavings are therapeutic
14858 posts in 2389 days
#2 posted 102 days ago
Thanks, Don. I’ve been cleaning them up for a while now, but I really need to start working more on my using skills.
getlostinwood
210 posts in 773 days
#3 posted 102 days ago
As one who has wanted to use my planes, and when I try they are cumbersome, hard to use and deliver bad results. This is a huge help. Thank you for making some of my mistakes clearer for me.
-- The basis for optimism is shear terror
AnthonyReed
1359 posts in 611 days
#4 posted 102 days ago
Thank you Don.
-- ~Tony
OnlyJustME
1367 posts in 547 days
#5 posted 102 days ago
Great info. :)
-- In the end, when your life flashes before your eyes, will you like what you see?
MikeyLikesIt
16 posts in 182 days
#6 posted 102 days ago
Very helpful info, thank you.
Brit
4196 posts in 1013 days
#7 posted 102 days ago
Great blog Don. One for the favourites.
-- Andy -- Old Chinese proverb say: If you think something can't be done, don't interrupt man who is doing it.
Handtooler
394 posts in 302 days
#8 posted 101 days ago
Super information and I’m sure Christopher Schwarz will agree in all of its entry.
-- Russell Pitner Hixson, TN 37343 bassboy40@msn.com
Dave
9189 posts in 1010 days
#9 posted 101 days ago
Don wonderful tips. As always I pick up a thing or two.
BTKS
1919 posts in 1635 days
#10 posted 99 days ago
Nice synopsis!
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
