Vintage Craftsman 306.9121 planer restoration #1: Planer restoration. The beginning.
Blog entry by Don W posted 07-22-2012 01:24 PM 14077 reads 2 times favorited 40 comments Add to Favorites Watch
no previous part Part 1 of Vintage Craftsman 306.9121 planer restoration series Part 2: OK moving right along »
So I won a planer on ebay for $39. I bid the starting bid never expecting to win. I figured for $39, the 3hp electric motor would cover it. This was the only picture supplied.
Last weekend I drove to pick it up. http://lumberjocks.com/topics/39731
Once home I gave it a systems check. Does it work? The description said “In working condition”, but what exactly did that mean.
Since the motor was not attached, I rewired it for 110V just to test it (will be put back to 220v for regular use). Plugged it in and it purred like a kitten.
I could see the bladed needed sharpening but wanted to make sure I could buy the parts that were needed. Doing some research I found that according to vintagemachinery.org the 306 in the serial number meant it was a Foley Belsaw, or now just Belsaw.
I called the number on belsaw.com and talked to someone very helpful. The Belsaw #9103 was branded under a lot of different names and numbers, the guy told me if it looks the same, it probably is the same. He admitted through company splits, a lot of the information was lost.
So other models seem to be
Craftsman 9123
Belsaw 910
Belsaw 9103
With optional components, this can become a molding machine as well.
Some other helkpful links were
http://vintagemachinery.org/Craftsman/manufacturers.aspx?sort=1
http://vintagemachinery.org/photoindex/detail.aspx?id=8872
http://www.belsaw.com/9103pl.html
Most parts are the same as 9103
http://www.belsaw.com/index.html
He also said a lot of the parts like the rollers and primary drive components are still in use on their models today.
He also gave me a list of common failures for the machine. He said sprocket #37 is the one that seems to wear the quickest. He also said another common problem is teeth missing on the raise assembly sprockets. After knowing I could get parts I turned my attention to the machine. I looked over all of the bushings and rollers. They look sound and I could not find any worn parts. This machine didn’t seem to have any of the above mentioned problems.
Next I cut some angle iron for motor mounts, made a new platform out of doubled 3/4” plywood and clamped it down, measured for a v-belt and ran to the parts store to pick up a new v-belt. They only had one, the other is on order.
Next I jerry rigged an extension cord and plugged it in. A few expected rattles, but nothing unfixable came from the sounds.
The blades were in dire need of sharpening. I took out my trusty makita horizontal grinder and sharpened the blades. While they were out I gave the cutter head a good scrubbing. According to the manual, you just loosen the set screws and tap down on the retainers. This proved to be true and the blades were removed with out any incident. A thorough cleaning of all parts before re-installation was performed as well.
The blades then went back in.
Next I cleaned the bed, wire brushed, sanded, and de-rusted until it looked respectable again.
With the motor still clamped in place, I ran a couple of board through it. How sweet. Compared to my Ryobi lunchbox this is going to be a charm.
The original motor mounts were held on with J hooks. I decided to make a few metal clamps. These will be painted.
The some dust collection. This isn’t complete, but you may be able to see where its headed.
So last night I picked up some hinges for the dust collection, bolts for everything, primer and paint, a length of 10-2 power cord, switch, box and plug and a few other misc parts needed.
Next up will be some painting. The closest color I could find was a dark grey machine paint. I don’t plane to totally strip it and paint everything, so I’ll deal with the variation. I’ll work on the dust collection.
So that’s it for part one. Thanks for looking. I hope to see you on the next installment.
40 comments so far
View kevinw's profile
kevinw
198 posts in 3979 days
#1 posted 07-22-2012 01:37 PM
I own one of these almost exactly the same if not identical. I paid $85 for mine. Weighs a ton. Overall works well. Sometimes the roller feed is a little reluctant, but if I keep the bed waxed I have run a lot of stuff through it with good results. Never been brave enough to take it apart much, so will watch your work with interest to learn some things. Good idea to make the dust hood.
-- Kevin, Blue Springs, MO
View Don W's profile
Don W
19050 posts in 2807 days
#2 posted 07-22-2012 01:43 PM
Kevin, I ran the first board through without anything to contain the shavings. My shop is 24 foot wide and it shot the stuff all the way across the floor. I knew it had to be!
Smitty_Cabinetshop
15822 posts in 2858 days
#3 posted 07-22-2012 02:56 PM
Looks like beast! Love old Craftsman iron. Congrats, Don!
View Dan's profile
Dan
3630 posts in 3120 days
#4 posted 07-22-2012 05:37 PM
Great find and restore is looking good.
-- Dan - "Collector of Hand Planes"
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 3096 days
#5 posted 07-22-2012 05:48 PM
Don, this is great
Cant beat the old heavies
I’ve a 1939 planer purrs like a kitten. :)
Looking forward to this build
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View bhog's profile
bhog
2238 posts in 2930 days
#6 posted 07-22-2012 07:45 PM
Those are very good machines Don.With a little love you will have a life long (and maybe kids too)tool there.Some of them had an atachment for ripping also.Pretty cool.Also if you ever do any moulding with it dont forget the counter weights….... lol…...
-- I don't drive a Prius.
View Mauricio's profile
Mauricio
7150 posts in 3391 days
#7 posted 07-23-2012 03:10 PM
Looks interesting, Molding and Ripping Attachments? Are you planning on hunting those down Don? Would be pretty neat.
Don W
#8 posted 07-23-2012 03:23 PM
Mauricio, I am not going to actively look for the Molding and Ripping Attachments. If I happened to stumble across a set though, I won’t walk away from them.
View Dave's profile
Dave
11429 posts in 3080 days
#9 posted 07-24-2012 11:34 PM
Don now that is going to be one hum dinger of a refurbish. Grats on the catch.
View Brad's profile
1140 posts in 2980 days
#10 posted 07-25-2012 12:45 AM
Don I had to laugh when I read this:
“I rewired it for 110V just to test it (will be put back to 220v for regular use). Plugged it in and it purred like a kitten.”
By contrast, had I ”rewired” it, I would have plugged it in to be greeted by a popping sound followed by a mini-mushroom cloud of smoke billowing to the ceiling.
That said, I was hesitant to take on my drill press rehab and I’m happy how that turned out. So, you’ve inspired me to expand my rehabbing horizons. Looking forward to some planer action shots.
-- "People's lives are their own rewards or punishments."
View steviep's profile
steviep
233 posts in 2887 days
#11 posted 07-26-2012 12:31 PM
thats great Don, I’m with Smitty- Love old Craftsman iron. congrats!
-- StevieP ~ Micheal Tompkins - you were not here on earth long but left a giant mark on us. RIP Brother
View Mike R.'s profile
Mike R.
214 posts in 2885 days
#12 posted 09-19-2012 10:25 PM
did it come with a craftsman motor ? i just got one that cam with craftsman badges and a craftsman motor and im trying to figure out how to wire it.
Don W
#13 posted 09-19-2012 10:27 PM
sure did. I snap a picture of the diagram and post it.
Don W
#14 posted 09-19-2012 10:46 PM
Mike R.
#15 posted 09-19-2012 10:54 PM
ok that is totaly not what i have , if i took a pic you wouldnt mind taking a look and helping out would you ?
showing 1 through 15 of 40 comments
