Just some planes restored #22: Checkering the Tote
Blog entry by Don W posted 07-06-2012 11:23 PM 4782 reads 5 times favorited 33 comments Add to Favorites Watch
« Part 21: Yes, the Pre-lateral may need some extra love. Part 22 of Just some planes restored series Part 23: Expect the unexpected. »
So after posting this http://lumberjocks.com/donwilwol/blog/30812 I had some request to show better detail on checkering. It had been a while since I checkered, but I have several firearms I did several years ago. This is just a few.
So lets look at how we would do this on a plane tote. First we need some files. I have 2 sets, 18 lines per inch and 22 lines per inch. I’m using the 18, again, because its been a while.
The four files are as follows, a 4 line cutter, a 2 line cutter, a rough single and a finish single.
First we’ll sand the tote to finish, then lay out the borders. I’ll start with a borderless again. It should come out like this.
But we’ll start with a cherry tote this time.
then we’ll lay out the borders. Note for firearms I have a bunch of templates.
But I’ll draw these freehand. Note I’m wrapping this around the back of the handle. Checkering through contours add a bit of time. I did the bloodwood shown above in one sitting. Tonight I didn’t make it.
So both sides are laid out, my magnifier lamp set up we’re ready to cut our first line.
I’m going to use the 2 line cutter. I never really liked the 4 line. It works well, but only on flat straight lines.
The idea is to cut to the border line. We’ll be using a combination of the double and single cutters.
Then just keep going, One line at a time, letting the double cutter use the last line as a guide. The trick is to get it deep enough for a good guide line.
Until one side is complete
then go back over everything one more time. I use the single cutter for this step. That way I can get all the way to the ends and keep everything clean and even. (well, that’s the theory anyhow)
Now start the same sequence again, but at about a 40 degree angle for the opposing line.
I managed to get a little further than this tonight, but must have forgot the last picture. So we’ll finish later.
So here is what I had finished last night.
Next will just just continue on side 1. After complete I’ll re-cut with the rough single cut. Then both sides get re-cut with the finish cutter. You continue with the finish until the checkers at almost to a point.
and some random shots as I cleaned it up.
And complete. You can see the one little mishap in the middle. I may be able to clean that up to.
So on to side 2.
For side 2 I’d like to present the jointer. Made for the long straight runs.
And this is as far as a got today. Off to a family affair.
More to come.
33 comments so far
View JayT's profile
JayT
5523 posts in 2116 days
#1 posted 07-06-2012 11:44 PM
Very cool, Don. I have cleaned up checkering when refinishing stocks, but never done it from scratch. It will be interesting to watch the whole process. Is there a significance to the 40degree angle, or just because it produces a diamond shape that is pleasing to the eye?
View Don W's profile
Don W
18605 posts in 2473 days
#2 posted 07-07-2012 12:03 AM
as far as i know its just because it produces the diamond shape. I have always just eye balled it.
View carguy460's profile
carguy460
801 posts in 2240 days
#3 posted 07-07-2012 12:37 AM
Don, this is awesome! I would like to try this someday – do you have a source for the cutters? Where would you reccomend I purchase a set from?
-- Jason K
View Dan's profile
Dan
3630 posts in 2785 days
#4 posted 07-07-2012 12:43 AM
Thats pretty cool. I would have never thought to try something like that…
-- Dan - "Collector of Hand Planes"
View bhog's profile
bhog
2236 posts in 2595 days
#5 posted 07-07-2012 12:47 AM
I like the idea Don.Will make for some interesting totes for sure.Do you plan on trying a knob after you have played with a few?
-- I don't drive a Prius.
Don W
#6 posted 07-07-2012 12:49 AM
http://www.brownells.com/.aspx/cid=11325/Products/Hand-Checkering-Tools
http://www.gunline.com/checkering.html
I’m pretty sure mine came from brownells but that was quit a few years ago. Watch ebay as well.
Don W
#7 posted 07-07-2012 12:53 AM
Brandon, i’ve thought about the knob. Its not enough surface to checker, maybe just some knurling.
View Dave's profile
Dave
11426 posts in 2745 days
#8 posted 07-07-2012 02:02 AM
Thank you Don. That is such and interesting process and detailed. Well done. I will defiantly keep this in mind.
View Smitty_Cabinetshop's profile (online now)
Smitty_Cabinetshop
15107 posts in 2523 days
#9 posted 07-07-2012 02:12 AM
Very nice addition to that tote, Don. Great idea to add checkering, but now rveryone will need a Don Yoda tote… :-)
carguy460
#10 posted 07-07-2012 03:10 AM
Thanks for the links, Don…
Smitty – I agree…everyone will want a checkered Don Yoda tote now! Don – you will need to raise your tote prices now…wait, I might want one or two….hold that thought…
-- Jason K
View rance's profile
rance
4256 posts in 3065 days
#11 posted 07-07-2012 03:22 AM
Now this is VERY interesting. Thanks for posting.
View Brandon's profile
Brandon
4152 posts in 2856 days
#12 posted 07-07-2012 04:32 AM
I’d like one checkered cherry tote, please. Thank you, Don. :-)
Great work—I’d like to try this sometime.
-- "hold fast to that which is good"
Don W
#13 posted 07-07-2012 04:09 PM
So day 2 progress has been added. I didn’t have much time in the shop today, so I didn’t get much done.
One thing I did was grabbed a crapping old knob to try out. Would it be enough? Do I need to cross hatch it somehow? Any other ideas.
View Brit's profile
Brit
7364 posts in 2748 days
#14 posted 07-07-2012 11:10 PM
Don said ”You can see the one little mishap in the middle.” Errr, no I can’t. :-)
bhog said ”Do you plan on trying a knob after you have played with a few?” On second thoughts, I won’t go there. Sorry Brandon, but that did make me a chuckle. LOL.
Great explanation and photos Don. I’ve never seen or heard of these tools before, so it was great to see how they are used.
-- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
View Dark_Lightning's profile
Dark_Lightning
3067 posts in 3014 days
#15 posted 07-08-2012 01:38 AM
I had an uncle who checkered his own gunstocks and bows. I always wondered how he did it, but never got around to looking into the process. Those files are on a par with my Pfeil carving tools for price…wonder if I can re-purpose them….nahhh.
-- Random Orbital Nailer
showing 1 through 15 of 33 comments
