Transitional restores #2: Transitional restore the dw way.
Blog entry by Don W posted 03-27-2012 01:57 PM 3170 reads 4 times favorited 11 comments Add to Favorites Watch
« Part 1: First transitional restore Part 2 of Transitional restores series Part 3: #34 What, a Jointer? »
A transitional bench plane can be a pleasure to use and they just look really cool. I’ve restored several, and each one tends to bring on a new challenge. Its a restore of wood and metal parts. Its not that hard to transform these into fine performing tools that are pleasing to the eye.
Click for details
Click for details
Click for details
First thing I typically do is take everything apart and place the parts in a container. I will often be restoring more than one plane at a time, and it is easy to start forgetting what part goes with what plane.
Its not that uncommon to have the parts rusted together. I typically wire brush as much of the rust off as I can. Some parts, like the cap iron, can be wire brushed to completion. Other parts, such as the frog will often have moving parts that you don’t want to try to take apart (like the lateral adjustment) and dips and hollows hard to wire brush. These go into evapo-rust. (For more option for removing rust, see my blog on bench plane restores ) Also, after some time in the evapo-rust, the parts should come apart easier.
The base will get the same treatment as the bench planes mentioned above. It is easier however to wire brush the base of a transitional without to much head ache. I will often wire brush them instead of setting up the sand blaster. I then paint the needed parts with Dupli-Color Engine Enamel DUPDE1635 Ford Semi Gloss Black spray paint.
All of the parts shown above are brushed with a course brush. When dealing with the brass parts, switch to a fine brush to avoid removing to much brass.
I also find the dremel brushes can help in these situations
I will the put a piece of rag over the piece and chuck it in the drill press. Depending on what is needed, I’ll sand the inside (inside only, and never if it has writing) up to 500 or 800 grit.
Give the iron and cap iron the same treatment as described in the bench plane blog buy ensuring a tight bond between the cap iron and the iron and polishing the chip breaking section. A cap iron blog is here.
After cleaning up the iron, give it a good sharpening.
Now off to the wood parts.
Restoring wood parts of a plane are the same as almost any wood restoration. If you have a favorite way, it probably can be incorporated.
I typically use a cabinet scraper on the bigger pieces first.
I then sand, some power, some hand sanding as needed.
Depending on the severity of the dryness, I will often soak the ends in BLO. I flip from end to end every so often and coat the entire plane. Once its removed, a complete wipe down to remove the excess.
Its not uncommon to need knob and tote repairs. Again, this is just typical wood restoration. I typically use Brownells Agraglass gel. I have used it in my gunsmithing hobby and know it works well. Any epoxy would work, and many just use glue, although I’ve seen glue not hold on the oily woods like rosewood. Also many times the break is old and hard to get really clean.
For a tip replacement, we’ll sand to get a good clean and flat surface.
then we’ll find a suitable piece. I typically don’t try to match. I’ve found it difficult to match the color and grain of such a wide variety of wood used.
Prepare it
Mix the epoxy. I like to add dye to color the mixture.
And typically with this type of epoxy, no clamping is required. Another big plus. Just be careful, when you walk away it will tend to slide if gravity has its way.
To sand the knob, (after repairs if needed) I have a bolt with the head ground enough to slide into the counter sunk hole, and will chuck it in the drill press.
Sand to 500 grit.
The knob gets the same treatment. I may soak them in BLO, or just coat, depending on condition.
And finally start the re-installation.
So the before and after shots of the 2 I restored for this blog.
An Upson #29
—After—
Sargent #3415. I don’t have a before pictures of the second. The reason. It looked so bad I didn’t think it was restorable. Yep, even I didn’t think it had possibilities. I planned to use the frog for another one of the High angle planes I planned to save as much of the base for future repair pieces. As I started scraping and sanding, this began to emerge.
The cap iron and iron are pitted so bad the iron will never be usable. I even tried the ruler trick but the pitting is to deep. I decided to paint the cap iron to hide some of the pitting. It will be a show piece until I stumble onto a new iron.
11 comments so far
View Brit's profile
Brit
7600 posts in 3079 days
#1 posted 03-27-2012 02:08 PM
As always Don, you did a wonderful job on those planes. Thanks for taking us through the process.
-- Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
View racerglen's profile
racerglen
3112 posts in 3017 days
#2 posted 03-27-2012 02:15 PM
Beauty of a blog and great refrence library.
Thanks Don !
-- Glen, B.C. Canada
View AnthonyReed's profile
AnthonyReed
10083 posts in 2677 days
#3 posted 03-27-2012 02:19 PM
Great job Don. Now i really would have liked to see the before picture, if you thought it was beyond hope it had to be a sight. Thanks for posting.
-- ~Tony
View Mauricio's profile
Mauricio
7150 posts in 3388 days
#4 posted 03-27-2012 02:21 PM
Wow, those look amazing!
View kaschimer's profile
kaschimer
89 posts in 2626 days
#5 posted 03-27-2012 02:28 PM
Really nice job, and a ton of good information. I have 4 planes that I inherited and need some restoration work done on them. This will help point me in the right direction.
-- Steve, Michigan - "Every piece of work is a self portrait of the person who accomplished it - autograph your work with excellence!" - Author unknown
View stefang's profile
stefang
16209 posts in 3571 days
#6 posted 03-27-2012 09:05 PM
Great work and a beautiful result.
View canadianchips's profile
canadianchips
2616 posts in 3234 days
#7 posted 03-27-2012 09:56 PM
Good tips.
I find restoring a transitional more rewarding than the metal ones. (Thats just me )
Just only thing.
NOW we will have to pay more money for “junkers” cause every one will be buying them ! LOL
View mafe's profile
mafe
11771 posts in 3326 days
#8 posted 03-27-2012 10:00 PM
I love the last one.
Find that iron!
Best thoughts,
Mads
View TechRedneck's profile
TechRedneck
770 posts in 3094 days
#9 posted 03-28-2012 02:12 AM
Don
As always.. Top notch.
-- Mike.... West Virginia. "Man is a tool using animal. Without tools he is nothing, with tools he is all.". T Carlyle
View SamuelP's profile
SamuelP
793 posts in 2883 days
#10 posted 03-28-2012 02:22 AM
Great job.
-- -Sam - FL- "A man who carries a cat by the tail learns somthing he can in no other way" -Mark Twain
View ShaneA's profile
ShaneA
7064 posts in 2835 days
#11 posted 03-28-2012 02:27 AM
Don, they both look great, buy the Sargent is super sweet looking. Well done….again.
