Planes restored - Because I can. #9: Plane Restoration, roll it together with a Millers Falls #10
Blog entry by Don W posted 09-15-2011 03:27 AM 16848 reads 30 times favorited 30 comments Add to Favorites Watch
« Part 8: Electrolysis Part 9 of Planes restored - Because I can. series Part 10: Sharpening past the DMT. »
So, I bought this bunch of planes in this pile which is shown with all the other weekend finds. Included at the bottom of the pile was this Millers Falls #10.
NOTE: This blog is not a suggestion to strip every plane and repaint. I actually would suggest otherwise if the japanning is in reasonable condition. Some are not savable and I don’t like tools that look terrible. If you can save it, I’d recommend that. If not, strip it.
I figured since this plane needed almost anything a plane restore could need, I would expand on it a bit and talk about my methodology for metal bench plane restoration, because when I pulled it from the pile it looked like this.
First i should note that you may find the occasional picture from another plane restore. I’m not trying to trick anyone, just get the details in and I can’t guarantee i have all the pictures I need from the Millers Falls #10. Most of my planes are Stanleys, but I have to admit I have a sort of soft spot for the good Millers Falls planes. Maybe its because they are the underdog, or maybe its the brighter shinier metal that I usually have to strip because its flaking away, either way, here we go.
First I take it all apart and put the parts in a plastic container. That to keep all the parts together as best as i can. I tend to have multiple projects happening in my shop, and since I don’t do this for a living, its possible i don’t get back for a few days or a week. I don’t want to have to remember where I put the parts. I then stand for a minute to contemplate what to start on first. The decisions are usually based on mood more than a real process.
Lets talk about the japanning. I’m a firm believer in leaving the japanning on an older plane if its reasonable. It could increase the value of the plane, but a lot of the planes I find the japanning is shot. Determining what to do next will take some trial and error if you’ve never done it, but here is what I use.
If you are just looking for clean up, what this http://lumberjocks.com/replies/612946
If you just want a good tune up, try this.
If your not going to repaint, its a good idea to give the japanned areas a couple of coats of shellac. This will bring back a bit of the luster and help protect both the japanning and any bare metal where the japanning is gone. If you don’t like shellac, a good waxing will do as well.
Electrolysis. Its a a great process and will get rid of the rust, or at least make it easy to brush off. I have used it and I will continue to use it at times. The draw backs are this. It takes a little time. You need to get it set up and it typically takes over night for most planes. You need a plastic container big enough for the piece your de-rusting and you need a battery charger. I will guarantee once you’ve used it you will continue if you plan to do this often. See Al's blog for further instructions.
Evapo-rust. Sold at some Tractor Supply’s and internet sites. Its $20 a gallon so its more expensive than electrolysis. A gallon will do a quit a few plane and other tools though. Just set the piece in it and let it set over night. Again the rust will either wipe off or wire brush right off the next day. I wire brush my parts first, just to make the evapo-rust last longer and try to keep it cleaner.
To use evapo-rust, you can use a plastic tote like the electrolysis, or I made an aluminum tray out of flashing material. Its narrower so it takes less to cover the plane. I can also tilt it in one direction so its deeper on one end.
VERY IMPORTANT NOTE. MAKE SURE THE WHOLE PIECE IS COVERED. EVAPO-RUST WILL LEAVE AN ETCH MARK AT THE WATER LEVEL THAT WILL NOT EASILY COME OUT!
I also made a wire basket for the smaller parts.
This is what the Millers Falls looked like when it came out of the evapo-rust. I had hopes I could save the japanning, but there was to much rust under the japanning that I didn’t see until it was lifted.
I knew it needed to be painted, so lets break out the sand blaster.
Sand Blasting. My favorite for planes that you know you need to paint. I bought a $30 sand blasting gun at amazon.com and haven’t looked back. Again, I try to leave the japanning if I can, but if it needs painting this is the way to go. Screened play sand will work just fine, but I bought some aluminum oxide blasting grit which works a little better. Don’t be afraid to stick with the play sand for a while. Its does a fine job. The draw back of sand blasting is you need a decent air compressor.
EDIT: I’ve noticed recently the sand blasting guns are even cheaper at Amazon.
I also created a small blasting cabinet. You can re-use the media and it keeps it contained. Plus it doesn’t get all over my shop.
Note most of it is plastic except for a piece of glass in the front. That’s so its easier to wipe off and see through. The bottom is open so I set it on my bench on a flat piece of steel (plywood would work too) to catch the sand. Note the 2 hand holes in the front. What you can not see is the top. I have 2 holes drilled in a piece of plywood. One is for the air hose. The other is for a shop vac. When using play sand for media, it helps to suck the dust out so you can see.
It takes me 30-40 minute to setup and clean a base using the Sand Blaster. Obviously doing 2 or 3 at once is quicker.
Edit 7-2013. Another Sandblasting upgrade. It works better than I anticipated. I like it a lot. Its highly recommended.
Take a look at my #8c restore for more picture of before and after sandblasting.
Edit 7-2013
Citric Acid. I finally ordered some citric acid to try out. This stuff is great. I had trouble finding it local, so I finally ordered it from Amazon. I started with a #1 bag, but it seems like even that small bag will go a long way. Just add water and some powder. I haven’t used it enough to know how much exactly, but I added about 1/4 cup to my 24” window box liner and I’ve done several planes in it so far. I had a broken plane and wanted to see what happened if I left it soak to long, so I stuck it in on sunday, took it out the next Saturday. I had a nice rust free plane with no adverse affect. I highly recommend this stuff.
Note the citric acid won’t strip the japanning, so it can be used like evapo-rust for de-rusting the planes you find that you’ll be saving the existing japanning. I love finding those!!
The old fashion way. Wire brushes and scrapers and screw drivers and sand paper and whatever else you have to work the stuff off. This is the hardest way, but if you plan to only do one or two, it may be your choice.
Paint Stripper. Paint stripper will work if added to “the old fashion way” above. It will usually take a few applications. I have used it but for me its messy and time consuming. Again, if you are only going to do a few planes, it may a choice.
Now lets move on to the frog
Next you will want to wire brush the frog so you can paint them together. I don’t have a picture wire brushing the frog, but you will want a course and a fine wire brush like this one:
There is usually a little hand work on the frog as well. I have some larger and smaller wire brushes I use. Use what ever works for you. I also have a collection of wire brushes for the drill. I will use whatever works.
Of course If your sandblasting the sole, the frog can be easily sandblasted as well.
It’s typically easier on the frog to tape off the areas to not be painted. If the base hasn’t been cleaned up I don’t bother, but If I have the rest of the base complete, I’ll mask it with painter tape.
Next paint it. Wipe it down with mineral spirits or paint thinner to get all the dust off it. I use Dupli-Color Engine Enamel DUPDE1635 Ford Semi Gloss Black spray paint I find the Dupli-Color to be a little closer to the original finish. What I like about the Dupli-Color Engine Enamel is you re-coat after 10 minutes. I usually let it sit for 15 minutes and add a coat. I will give it 4 or 5 coats. VERY IMPORTANT Note you can not re coat if you wait longer than about 1 hour though. If it starts to set up the fresh paint will cause the semi dry paint to peel and curl up. If you need to repaint wait 7 days as described on the can.
NOTE: If you want to try traditional japanning, here is a very very good series, http://lumberjocks.com/JayT/blog/series/5621
I try to paint the frog and base together just to save time.
I may take the fork off if it comes apart easily. I paint the fork as well.
Next Polish the sides of the base. I use a belt sander if they need it, but have done a few by hand sanding. I find most can be cleaned up well enough with the wire wheel. It really depends on how much shine you’re looking to get. I like the flat luster from the wire wheel.
Flatten the frog. File the frog flat. It really doesn’t matter if you do this before or after painting. I usually wind up doing it after. I lock it in a vise and hold the file flat while filing it. It doesn’t need to be perfect. Some like to polish this as well, but its not really necessary.
Check and fix the cap iron. First thing I do is wire brush it. It should be re-rusted by now with whatever you decided, or you can just wire brush it. I find I will wire brush it first, then throw it in the evapo-rust if It still needs a little help. You can also touch it to a belt sander to shine it up a bit if needed. I go into more detail here.
Sharpen it After cleaning up the iron (just like the cap iron) you’ll need to sharpen it. How I go about that process is described here.
Now for the wood. I chuck the knob in the drill press.
I use a bolt with a 1/4” Philips head that’s been ground down slightly so it fits inside the knob where the brass nut goes. Tighten it down with a washer and chuck it in the drill press. Only chuck it hand tight so you don’t trash the threads.
Sand it with 60 grit if it still has a varnish or hard finish. then up through 500 grit. If it had an oil finish I’ll start with 220 grit. First few coats of BLO goes on with steel wool while in the drill press. If the exisitng finish is hard, it is usually easier to scrape it first.
For the tote, I haven’t found an easier way than possibly scraping if its a hard finish, and sanding as you would any other piece of wood.
Finish the wood with boiled linseed oil (BLO). If its a really dry old piece, soak it in tyhe BLO overnight.
If you need to make a new tote.
If you need to fix a broken tote
For the adjustment knob, I wire brush the outside. I try the fine brush first, if its bad enough you’ll need to start with the course, just be careful, you can take the ridges off. Then I chuck it in the drill press. I will add a piece of paper towel or rag between the jaws and the knob to protect it. Just tighten it hand tight. I then rip some pieces of sand paper about 1/4” by 1” and sand the inside. If its bad I’ll start with 120 grit up to 500 grid.
The brass nuts that holds the knob and tote on will go straight to the buffing wheel.
Cap Irons get wire brushed. I usually leave it with the brushed look. This Millers Falls was chromed, but it was shot, so I took it right off and left it. I painted this one on a Solar.
To get the red background, I will mask the outside ouline, paint it, let it dray and sand it with a sanding block. 220 grit, 320 grit, and 500 grit works for me.
Next flatten the sole. I don’t have a piece of granite yet, so I’m still doing it on the table saw top. If it proves to be real bad, I’ll start it on the belt sander, like I do the sides, but I always finish it on the flatter surface of the table saw. Turn the plane front and push in all directions to keep it flat and even.
Wire brush all the remaining screws and washers. I typically add a little axle grease before putting the screws back in.
As I’m putting everything together I give it a coat of Fluid Film to keep the rust away.
Or Wax it
And a few more “After” pictures.
For more information, check out the links on my refernece blog.
If you use this blog, don’t forget to post the pictures for us to see.
30 comments so far
View CharlesAuguste's profile
CharlesAuguste
126 posts in 2542 days
#1 posted 09-15-2011 03:59 AM
Beautiful work Don !! well done!
-- "the future's uncertain and the end is always near" J. Morrison
View tsangell's profile
tsangell
216 posts in 2694 days
#2 posted 09-15-2011 07:27 AM
Now that is a remarkable transformation. You saved Mr. Miller from the junkheap of history.
View Brit's profile
Brit
7376 posts in 2843 days
#3 posted 09-15-2011 09:16 AM
Great blog Don. Thanks for putting it together. I’m sure many people (including myself) will find this useful.
-- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
View AttainableApex's profile
AttainableApex
347 posts in 2833 days
#4 posted 09-15-2011 09:37 AM
good job
-- Ben L
View mafe's profile
mafe
11725 posts in 3090 days
#5 posted 09-15-2011 11:21 AM
Nice blog, always wonderful to se one of these come to life again.
And finteresting to so how you work.
Sweet plane!
Best thoughts,
Mads
View racerglen's profile
racerglen
3112 posts in 2781 days
#6 posted 09-15-2011 12:45 PM
Real nice work, and a great blog !
(don’t know how you manage to get so much done AND find the time for the pix and writing as well..neversleep ? )
-- Glen, B.C. Canada
View Don W's profile
Don W
18718 posts in 2568 days
#7 posted 09-15-2011 02:30 PM
Well Glen, you may have heard this before, but I typically travel a lot for my job. Its not uncommon from me to leave my house monday morning and not resturn until thursday or friday for several weeks in a row, but a while ago I pulled a rare project. First, it goes until xmas, which is longer than typical, and second, its commutable from home. This gives me evening in my shop. Since its rare, I am taking advantage of it and loving every minute of it. Real life will return soon enough.
racerglen
#8 posted 09-15-2011 02:54 PM
Taking advantage while you can..great idea and the rest oif us benifit as well..
View mcoyfrog's profile
mcoyfrog
4145 posts in 3595 days
#9 posted 09-15-2011 08:46 PM
Great post, I’m gonna have to hit the garage sales and get me another project woo woo
-- Wood and Glass they kick (well you know) Have a great day - Dug
View gawthrrw's profile
gawthrrw
207 posts in 2448 days
#10 posted 09-16-2011 12:44 AM
Love it! I’ve restored a few of these also. It’s awesome to see them come back to life.
-- Rob, Dallas TX
View Dan's profile
Dan
3630 posts in 2881 days
#11 posted 09-19-2011 06:32 PM
You punch these things out so quick it makes all my restoration work look so slow. lol…
Very well done. Great looking plane.
-- Dan - "Collector of Hand Planes"
View clafollett's profile
clafollett
114 posts in 2655 days
#12 posted 11-20-2011 04:23 AM
Excellent work!!! I’ve got this one book marked for easy reference. I have several old planes I’ve been collecting with a few needing the full monty. Thanks for the fine details.
-- Don't mind me, I'm just soaking up knowledge
View ShaneA's profile
ShaneA
6929 posts in 2599 days
#13 posted 11-20-2011 04:49 AM
Great info, well written and very informative. Great restore job. Thanks for taking the time to share, someone could learn a lot here.
Don W
#14 posted 11-20-2011 04:21 PM
thanks for the comments. I’m always open to suggestions. If you have or find a new, different way to approach these task, I’d love to hear them. I try to update this once in a while, so stop back now and then.
Smitty_Cabinetshop
15354 posts in 2619 days
#15 posted 11-30-2011 07:31 AM
Wonderful reference, Don!
showing 1 through 15 of 30 comments
