Hand Saws #9: Bow Saw build
Blog entry by Don W posted 08-05-2011 02:36 AM 5187 reads 7 times favorited 16 comments Add to Favorites Watch
« Part 8: S. Biggin & Sons Backsaw Restore Part 9 of Hand Saws series no next part
So I’ve wanted to build a bow saw for a while. My goal was to get it completed this week.
Additional finished pictures in the project.
Wood used was Ash for the frame and white oak for the rope tightener.
So I started by cutting the 2 side pieces. I marked them out free hand and cut them on the band saw.
Next I cut the mortise. So forgive me I used the machine.
I used the radial arm saw to cut the tenon, and cleaned it up with the shoulder plane and chisel.
I then took two 5/16 bolt over to the metal band saw. I cut the heads off. I drilled a 5/16 hole through a piece of scrap wood so I could cut the slot for the blade.
I drilled the hole through the bolts for the blade pin. I cut a section of band saw blade and drilled the holes in it.
Then its off to the make the handles. Off to the wood pile.
I cut 4” off the firewood stick for the 2 handles.
Off to the lathe. 2 cool points. I got to use a new live center I bought and the new tool rest I made.
I then drilled and tapped the handles. I’m not sure if I will epoxy these in, or pin them.
Its now sitting on my bench with a coat of Danish Oil. Tomorrow, I hope to have a finish picture.
16 comments so far
View David Grimes's profile
David Grimes
2078 posts in 2692 days
#1 posted 08-05-2011 02:47 AM
Great steps through the process. It made me feel like I helped you with it. Very nice work. Makes me secretly want a lathe. :=)
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View venicewoodworker's profile
venicewoodworker
100 posts in 2682 days
#2 posted 08-05-2011 02:57 AM
Very nice…...I just bought 2 saw blades (24 in) to make a rip and crosscut saw. Now you inspired me to get out and complete them.
Will post later.
View PurpLev's profile
PurpLev
8539 posts in 3701 days
#3 posted 08-05-2011 03:05 AM
great build Don, this one is on my list whenever I’ll have the time for it. thanks for the reminder. some great ideas here.
View MShort's profile
MShort
1790 posts in 3471 days
#4 posted 08-05-2011 04:38 AM
Very Cool !!! I will have to try this. Thanks for the great instructional.
-- Mike, Missouri --- “A positive life can not happen with a negative mind.” ---
View WayneC's profile
WayneC
13754 posts in 4150 days
#5 posted 08-05-2011 06:23 AM
Well done. I plan to make one when I get back into the shop and the shop is in order.
View saddletramp's profile
saddletramp
1180 posts in 2691 days
#6 posted 08-05-2011 01:12 PM
Great tutorial and a very nice saw.
-- ♫♪♪♫♫ Saddletramp, saddletramp, I'm as free as the breeze and I ride where I please, saddletramp ♪♪♪♫♪ ...... Bob W....NW Michigan (Traverse City area)
View mafe's profile
mafe
11734 posts in 3142 days
#7 posted 08-05-2011 04:14 PM
That sure looks migthy good!
What a fine saw you have made, you are becoming a real self made man now.
What drill did you use to drill in the blade? I guess a HSS will just burn…
Beautiful chisel in the top left corner on the last photo.
Best thoughts,
Mads
View Don W's profile
Don W
18789 posts in 2620 days
#8 posted 08-05-2011 05:34 PM
David, use a lathe once and you’ll wonder why you didn’t get one years ago.
Mads, thanks for the commnets. What you see in theat last photo is actually a vintage screw driver. I’m not sure why its there, left over from the previous project maybe, or a “sub” project working in tandem.
I’ve still got some writing to do, and a box from woodcraft just arrived. Sometimes working from home can be a problem. Just a few more paragraphs, then it maybe break (shop) time.
View mafe's profile
mafe
#9 posted 08-05-2011 06:24 PM
Ahhhh! Merci.
Yes once a lathe always a lathe.
Big smile,
Mads
View DaddyZ's profile
DaddyZ
2475 posts in 3093 days
#10 posted 08-05-2011 06:46 PM
Sweet!!!!
View Mauricio's profile
Mauricio
7144 posts in 3204 days
#11 posted 08-12-2011 08:31 PM
Nice Saw, This is one on my to do list.
I like the idea for using the bolts as saw holders. And I think its awesome to use the branch for the handles. I have some branches from my oak tree I’ve bee saving that would work well.
How is that piece of band saw blade working out for you? It looks like a pretty aggressive pitch on the teeth.
View Johnnyblot's profile
Johnnyblot
319 posts in 2329 days
#12 posted 05-19-2012 02:03 PM
Very Nice Don- another one for the ‘To Do List’
Cheers
John
-- Gossamer shavings just floating around the back yard….-Bandit
View Emma Walker's profile
Emma Walker
560 posts in 2163 days
#13 posted 01-24-2013 06:39 PM
I just Googled “how to make a bow saw” and guess what I found… a Don W thread on lumberjocks!
Does anyone know of any printable bow saw templets?
-- I'm a twisted 2x4 in a pile of straight lumber.
View waho6o9's profile
waho6o9
8240 posts in 2630 days
#14 posted 01-24-2013 06:53 PM
waho6o9
#15 posted 01-24-2013 06:56 PM
http://www.toolsforworkingwood.com/store/more/bowsawplans.html
Gramercy has kits as well. Great folks to deal with and I’ve found them also
to be helpful on the phone.
