dw's shop tips #1: 3-4-5 rule.
Blog entry by Don W posted 07-02-2011 02:38 PM 2699 reads 5 times favorited 3 comments Add to Favorites Watch
no previous part Part 1 of dw's shop tips series Part 2: Threaded inserts? Really. »
You want to square your project. Its to big or to small for a square. Maybe you can’t reach one corner to do a corner to corner comparison. Use the 3-4-5 rule.
The rule state simply if one side of a triangle is 3 and the other side is 4, the diagonal measurement will be 5. This can be inches, feet, millimeters, miles, arms lengths, anything as long as they are all the same.
Any set of numbers divisible by these will work. Need longer, double them for 6 – 8- 10.
Use the rule in conjunction to double check yourself.
Use it to check your square.
Use it to make your new “antique” wooden square.
3 comments so far
View Tedstor's profile
Tedstor
1643 posts in 2654 days
#1 posted 07-02-2011 08:06 PM
One of the most useful formulas around. I’ve done a couple of flooring proects in my home. Since I don’t own a 16 foot framing sqaure, the ole 3-4-5 rule was invaluable.
18615 posts in 4182 days
#2 posted 07-03-2011 01:28 PM
the first time I saw that used to square up a deck, I was “in awe”. Of course, I always forget what the numbers are and have to do a little math in my head :)
A great tip!
View bigike's profile
bigike
4052 posts in 3310 days
#3 posted 07-03-2011 06:08 PM
Thanks for the reminder. I’m gonna have to use this on my next box or picture frame. THANKS again.
