Just some planes restored #8: Solar Mfg Co #3
Blog entry by Don W posted 690 days ago 3103 reads 0 times favorited 7 comments Add to Favorites Watch
« Part 7: The #7 Part 8 of Just some planes restored series Part 9: The #4 FrankenPlane »
Interesting story to tell. I was headed out this afternoon to run some errands. We stopped at an antique mall that we stop at a lot. Several of the vendors have some nice tools, but they are typically very pricey. Today I found this plane for $12, it was marked Solar Mfg Co. on the blade and that was the only marking. I can’t find any information on it. Its a little unusual to find a #3 like this. Something about this plane told me to take it home.
The real reason I wanted it was it looked exactly like a Stanley, it was a #3 (i’ve got 3 now) and the blade was thicker than everything I have now.
The frog is exactly like my broken #3. It fits perfect with one exception, the adjustment screw is right handed. The adjustment screw is also steel and not brass. It doesn’t have a lateral adjustment lever. If it wasn’t for the right handed screw I’d think about switching.
The lever cap is painted black. It also doesn’t have a spring on the back. There is no marking on the bed other than made in the us.
I just thought it was different. I’m sure it will work just like a stanley. I’ll clean it up and add it to the collection.
I decided to clean it up and see how it would come out. The handles were not rosewood, probably beech,
After sanding I gave them a coat of walnut stain to darken them a little. Then the typical BLO coat or three.
and the screw holding the handles where just regular tapered screws, not the Stanley type brass nuts.
Above I said the iron adjustment knob was steel. It wasn’t, it looked like brass, but didn’t come out as bright as a typical Stanley would have.
The cap was painted black. I planned to leave it unpainted but didn’t like the way it looked. For some reason the red can of paint jumped out at me, so that’s what it got.
It still came out fairly nice. It seems to work well.
7 comments so far
View CharlesAuguste's profile
CharlesAuguste
126 posts in 707 days
#1 posted 690 days ago
Ive heard of Solar Mfg co, seen then come up once in a while on ebay but more frequently around Ma since they were made in Worcester MA up to the 70’s, mainly knock off of others! yours look pretty good!
-- "the future's uncertain and the end is always near" J. Morrison
View WayneC's profile
WayneC
9596 posts in 2263 days
#2 posted 689 days ago
Looks like a good usable little plane. #3’s get extra points for being cute. : ^ )
View RGtools's profile
RGtools
2829 posts in 820 days
#3 posted 689 days ago
I don’t know if you hollow grind or not, but be careful about the angle on that plane. The increased angle that thickens the tip of the blade really makes a difference when you sharpen I just about ended up with a bevel of 20 degrees because of that.
-- Make furniture that lasts as long as the tree - Ryan
View Bertha's profile
Bertha
13111 posts in 859 days
#4 posted 689 days ago
It’s got a fat tapered iron, if I’m seeing correctly. I would have ran with it, too, having never heard of it.
View Don W's profile
Don W
9932 posts in 733 days
#5 posted 689 days ago
Good info. I’ll watch for that. Also I noticed when I tried to put the blade in my 5 1/4 the screw on the chip break is no longer long enough with the thicker blade. When you order a hock or similar blade, do you need to order a replacement screw as well?
RGtools
#6 posted 689 days ago
no. The screw really becomes an issue on the chip-breaker. When you run into issues is when the lever adjuster can’t reach through the blade (due to thickness) and seat in the chipbreaker. Rob Cosman sells a blade and chipbreaker set that rectifies this (but I would just buy a blade the matches thickness)
View sprevratil's profile
sprevratil
565 posts in 812 days
#7 posted 657 days ago
That Iron looks like a siegley.
-- -Sam - West Virginia -
