Today I needed to replace a missing knob on a cheaper #4 I wanted to tune and get working. I wanted to make one, but I don’t have a lathe. I figured there had to be a way to do it with my drill press. I tried drilling a hole in a block and locking it down with nuts on a threaded rod, but the nuts kept coming loose, even though I doubled them to lock them.
I knew I needed something a little more substantial until I can pick up a lathe. I found an old drill that didn’t work anymore. I pulled the chuck and bearing end. In this case, the drill was so cheap, it wasn’t even a bearing but a bushing. I drilled a hole in a block of wood the size of the bushing (or bearing) and drove the bushing into the hole.
I then drilled a hole next to the chuck to place a rod to act as a tool guide. I didn’t need to attach the top, it sat in a groove where the spring case met the drill press frame, but you may want or need to attach it.
I then needed a drive center and a live center. Looking around the shop I found a couple old forstner bits. I chucked one in each chuck, made sure the bottom and top were centered, marked the center of the wood blank, raised the bed to tighten the blank and made sure the bits were connected in the blank.
I then happened to have a few turning tools, but some rasps would probably have worked as well. I created a guide from a piece of 1/4”plywood to match the knob I wanted to reproduce. Once it was shaped, I could sand and finish as I normally do.
Note this particular piece of wood was something I grabbed off the firewood pile. Next one will be a little better quality.
Also I found shaping worked best with the drill press spinning at a higher speed. Then I slowed it down a little for sanding.
Hope it helps
dw
2 comments so far
DaddyZ
home | projects | blog
2000 posts in 1206 days
#1 posted 716 days ago
Nice Job so far !!
Dennisgrosen
10854 posts in 1281 days
#2 posted 716 days ago
thank“s for sharing
Dennis
