pics for routing tip (REVISED)
Blog entry by dlcarver posted 596 days ago 373 reads 0 times favorited 10 comments Add to Favorites Watch
Here is a tip for some jocks who have to do a lot of routing on smaller and quick projects, especially if they are making small signs. This tip can be used on larger projects as well with a little adaptation. I learned of this from a little old sign maker about 30 years ago. I met him at a craft show…. I was carving and he was making signs. He was routing signs on the table top without using any clamps. I thought, “Boy is that cool or what? ” What he did was take two strips of sand paper and glue them back to back, then lay the sign on them…. placing the sand paper at each end, just a few inches in ….... the pressure down, or the weight of the router kept the signs from sliding while routing. You can see in pictures #4 and #5 that I am doing projects as small as 2” x 3”. You can also use this tip for routing molding around plaques as long as the bits don’t go below the thickness of the wood you are routing. Although I am due to change sand paper, I have been using the same one for about 30 years now. I improvised some what, by taking a 6” x 48” medium grit sanding belt and clamping it to my work bench at each end. This set up could slide easily without the clamps…. BUT THE WORK WILL NOT SLIDE. I use this system every other day, so it is probably one of the most useful tips I have ever picked up from anyone. I made a 1/4” clear plastic face plate for my router so I could see more clearly the small projects and the lines I have to follow. I never bought a router with out a light after the first one without the light. I’m sure there are jocks out there that know this little trick….... but I bet there are a lot more that don’t know of it. ENJOY
-- Dave Leitem,Butler,Pa.,http://dlcarver.etsy.com
10 comments so far
View dlcarver's profile
dlcarver
260 posts in 622 days
posted 596 days ago
ALTHOUGH THE PICS ARE BIGGER THAN I WANT THEM, AT LEAST THEY ARE THERE THIS TIME.
View Sawdust2's profile
Sawdust2
1181 posts in 980 days
posted 596 days ago
You can go back to Flickr (or whereever) and resize them. It took me a while to figure that out.
dlcarver
posted 596 days ago
THANKS LEE
DAVE
20554 posts in 714 days
posted 596 days ago
Thanks for the pictures, Dave. I tend to understand a new concept better if I have some visual aides to go along with the text.
dlcarver
posted 596 days ago
My wife is worried about showing my dirty shop. I am not a very tidy shop keeper, I don’t have time to run the vaccum every time I do a little job….. but a lot of little jobs mounts up to a big mess. I clean when I have to…... WHEN MY STOOL STARTS TILTING AT A 30 DEGREE ANGLE,.... IT’S TIME TO CLEAN. HA, HA HA!!!
View John Gray's profile
John Gray
1752 posts in 778 days
posted 596 days ago
Neat idea, THANKS!!!!
3710 posts in 872 days
posted 596 days ago
Hi David;
I see there’s an impostor using my name1 LOL He doesn’t even look like me.
Or maybe his name really is Lee. Nah, can’t be.
This is a great idea for holding things from slipping.
View GaryK's profile
GaryK
9521 posts in 881 days
posted 596 days ago
Lots of sawdust! I like that.
View Chris 's profile
Chris
1467 posts in 883 days
posted 595 days ago
Very nice idea…
-- Chris
View aussiman's profile
aussiman
24 posts in 625 days
posted 559 days ago
great idea a question on a different thing can you tell me were you get the burr you have in the router it looks good
