ROUTING TIP
Blog entry by dlcarver posted 598 days ago 294 reads 1 time favorited 7 comments Add to Favorites Watch
Here is a tip for some jocks who have to do a lot of routing on smaller and quick projects, especially if they are making small signs. This tip can be used on larger projects as well with a little adaptation. I learned of this from a little old sign maker about 30 years ago. I met him at a craft show…. I was carving and he was making signs. He was routing signs on the table top without using any clamps. I thought, “Boy is that cool or what? ” What he did was take two strips of sand paper and glue them back to back, then lay the sign on them…. placing the sand paper at each end, just a few inches in ….... the pressure down, or the weight of the router kept the signs from sliding while routing. You can see in pictures #4 and #5 that I am doing projects as small as 2” x 3”. You can also use this tip for routing molding around plaques as long as the bits don’t go below the thickness of the wood you are routing. Although I am due to change sand paper, I have been using the same one for about 30 years now. I improvised some what, by taking a 6” x 48” medium grit sanding belt and clamping it to my work bench at each end. This set up could slide easily without the clamps…. BUT THE WORK WILL NOT SLIDE. I use this system every other day, so it is probably one of the most useful tips I have ever picked up from anyone. I made a 1/4” clear plastic face plate for my router so I could see more clearly the small projects and the lines I have to follow. I never bought a router with out a light after the first one without the light. I’m sure there are jocks out there that know this little trick….... but I bet there are a lot more that don’t know of it. ENJOY!
-- Dave Leitem,Butler,Pa.,http://dlcarver.etsy.com
7 comments so far
20603 posts in 715 days
posted 598 days ago
Thanks for the tip Dave. I will have to try this.
View GaryK's profile
GaryK
9521 posts in 882 days
posted 598 days ago
Kind of like using a sanding pad. Thanks.
View skozub's profile
skozub
59 posts in 652 days
posted 597 days ago
Thanks for the info
View dlcarver's profile
dlcarver
260 posts in 624 days
posted 597 days ago
SORRY GUYS! THERE IS SUPPOSE TO BE 5 PHOTOS TO GO WITH THIS BLOG. AS SOON AS SOMEONE TELLS ME HOW TO GET ALL 5 PHOTOS FROM MY PHOTOBUCKET TO MY BLOG….YOU’LL HAVE THEM.
THANKS DAVE
View coolbreeze's profile
coolbreeze
105 posts in 629 days
posted 597 days ago
Thanks for the tip, Dave. I use the rubber holey pads that you buy to hold rugs in place for sanding and holding stuff still. I’m gonna try this, too.
-- Jason, AL
View cajunpen's profile
cajunpen
5968 posts in 959 days
posted 597 days ago
Good tip Dave, Thanks.
View DAN 's profile
DAN
6439 posts in 876 days
posted 597 days ago
great tip Dave ... I will try this idea soon
