Bedroom Wall Unit #10: creeping along...howdoyado?
Blog entry by depictureboy posted 01-05-2011 04:15 PM 1349 reads 0 times favorited 0 comments Add to Favorites Watch
« Part 9: Moving upstairs Part 10 of Bedroom Wall Unit series Part 11: Home Stretch...I can see the finish line »
well things are progressing, this coldness has really slowed things down alot, both just because you cant do alot when its cold, and its messed with my motivation some…
anyway I have started on the drawerfronts for under the bed since I can get them inside for the glue and finish to cure as needed.
here are a couple pics…
dry fit
first coats of finish, dry fitting in the opening
-- If you can't build it, code it. If you can't code it, build it. But always ALWAYS take a picture.
0 comments so far
