Drill two holes in the fence . one a little larger.. to take 1/4 ” bolts . Mark these positions on the base and drill these holes to attach the fence to the base. One bolt is held with a nut and other with a Knob.[for adjustment in fine tuning the fence if necessary].
Drill two addition holes in the fence to accept 1/4 ” bolts for tightening the bridge clamps.[These holes got through the fence only] Refer to the photo.
In his pic you may see that I inserted a bearing to serve as a bushing so that the hole would not wear with the amount of use it will be seeing.[the jig pivots on the bolt in the circle cutting jig..
A few different angles.
If you don’t get a good fit on all twelve pieces you can undo the knob at the back and adjust the fence in or out
Thats about It not really much to it at all
-- Drink twice... and don't bother to cut... @ lazylarrywoodworks.com.au For lovers of all things timber...
30 comments so far
Peik Löf
home | projects | blog
115 posts in 1569 days
#1 posted 1478 days ago
“not really much to it at all”
Pfft, that jig is awesome :D
-- My signature is awesome.
degoose
6619 posts in 1551 days
#2 posted 1478 days ago
Peik.. just 4 pieces of ply and wood and some nuts and bolts and knobs and a bearing.
Not much at all.. but I agree It is bl**dy awesome.
It as change all my thoughts about how I make things.
stefang
9725 posts in 1531 days
#3 posted 1478 days ago
The thing I still can’t understand is the template. Am I right in thinking that the width of the template determines the width of the pieces to be cut?
-- Mike, American in Norway
degoose
#4 posted 1478 days ago
NO
Splinterman
23056 posts in 1558 days
#5 posted 1478 days ago
Sheesh….....Larry….dont bite Stefang’s head off…..ROFLMAO..!!
bowyer
340 posts in 1593 days
#6 posted 1478 days ago
Thanks for this great blog series!!
Rick
-- If at first you don't succeed...Don't try skydiving
12166 posts in 1538 days
#7 posted 1478 days ago
the radius is large enough so the kerf is neglijable .
in tighter raduis it would matter .
good work mate !
Charles Maxwell
828 posts in 2004 days
#8 posted 1478 days ago
Thanks for this post. You gave my a great idea for assembling my gear blanks with spiral shapes vs the straight pie cuts I’ve been using. Thanks for the post. I’ll let you know how the gear blanks work in my new clock designs! Of course, you get all the credit. Max
-- Max the "night janitor" at www.hardwoodclocks.com
stefang
#9 posted 1478 days ago
Everybody seems onboard with this last blog while I’m still on the quay. Anything besides a NO Larry? Like what does the width of the template determine?
stefang
#10 posted 1478 days ago
Ok, I finally got it. But the template does determine the the shape of the segment including the width. Am I not right?
degoose
#11 posted 1478 days ago
Mike you got it …it’s not about the width per se but the shape of the template. The width does determine the number of pieces in the finished circle but the shape is all you need.
BTW Mike didn’t mean to be rude just trying to get you to work it out and you were on the right track.
degoose
#12 posted 1478 days ago
A little secret.
The arcs on the template are just segments of the circle with a 9.5 inch radius.. You work out the width for the number of pieces in the circle.
spanky46
969 posts in 1587 days
#13 posted 1478 days ago
If I say I understand all of it do you think I’m smart or lying?
Nice work Larry.
-- spanky46 -- Never enough clamps...Never enough tools...Never enough time.
degoose
#14 posted 1478 days ago
milehigh
54 posts in 1537 days
#15 posted 1478 days ago
Thank you for sharing your time and talent here on the forum Larry. I really enjoy your blogs and this one is no exception.
Paul
View all comments »
showing 1 through 15 of 30 comments
